Service nightmare
seems fair! you get them and if they aint right I'll buy them from you.....
from memory, the coil was in two different places on the early 340. The 343 i think has it by the radiator ( as does my 1983 340 ) but from B reg onwards they moved it... maybe to where the Renix is?
where is the coil in your car and what year is your 340?
all the best
shimon
all the best
shimon
Enjoy your 300s
- antiekeradio
looks like our cars are the same then...
so if the leads dont fit yours I dont think they will fit mine. I think the only problem is the one to the coil being too short.
Ive found some more parts info for you... check out the post called
Ignition types for 1.4 340s in the general technical section
all the best
all the best
Enjoy your 300s
The problem is not the length of the cable, but that it has two female ends. Both the coil and distributor on my car have female connectors requiring a male end to the cable at each end. I'm going to play around with the car again tomorrow afternoon and hopefully get it going properly but I'd rather like a matching set of leads.
That pdf you posted looks helpful Shimon, but what manufacturer's parts do the numbers refer to?
those are quinton hazel part numbers for igntion systems. The guy from there emailed me part numbers for the volvo 66 this morning and im waiting for a fax for the 340 stuff now.
Im going to keep posting all the parts info that I find.......
Re the cable... this is just like my 240 2.1 which needs a male connector at each end of the cable. I simply got a double ended one from a local car parts shop. It works and is cool. However, Im subsequentially learning from wouter that you need to check resistances for different cables...
Ive changed the cables on my 1983 340 for silcone ones without a problem. however, wouter said these have a higher resistance than the originals....im a bit confused now
need to do some more research for this one!
however, quinton hazel list the parts for your car and I have a list of their stockist on manchester
here are three of them for manchester..ive got andrew pages number for you.......
Steves Super Spares
350 Gt Cheetham St East, Salford, M7 4UJ
Andrew Page Ltd
Unit 9, Lapwing Court, Salford, M5 3EY
Tel : 0161 848 7557 (Sales)
Manager: JASON HANRAHAN
TMS Autoparts
272-274 Oldham Road, M35 0HB
look forward to hearing all about any updates!!!
Steves Super Spares
Andrew Page Ltd
TMS Autoparts
Enjoy your 300s
- antiekeradio
i see!!
thanks for the info wouter!
my 240 has a breaker ignition so that would apply here...
for the Renix there is less to woory about... cool
PS dya know where I could get the ignition maps for the B13, B14 and B17. do you think the daf club might have these?
alternatively, Im going to try volvo but being a renault engine it might all be archived at renault and ive never contacted them for technical info before.........
thanks mate for the info
Enjoy your 300s
info for you to ask your motor shop
these are quinton hazel parts
Volvo 340 1.4 Delco 1979-1983
Contact set - XCS121
Condensor - XCON78
Distributor cap - XD82
Rotor arm - XR103
Ignition coil - XIC8029
Volvo 340 1.4 Ducellier 1976-1978
Contact set – XCS90
Condensor – XCON79
Distributor cap – XD314
Rotor arm – XR104
Ignition coil –XIC8029
Volvo 340 1.4 Ducellier 1978- 1983
Contact set – XCS90
Condensor – XCON79
Distributor cap –XD140
Rotor arm – XR104
Volvo 340 1.4 Ducellier 1983 onwards ( Renix )
Ignition module – XEI4
Condensor – N/A
Distributor cap – XD141
Rotor arm – XR160
Ignition coil –XIC 8076
Not sure why its lists ignition module and coil… unless module refers to the control unit mounted on the wing and ignition coil refers to the actual renix unit on the inner wing
Volvo 340 1.4 SEV 1979-1983
Contact set – XCS149
Condensor – XCON123
Distributor cap – XD125
Rotor arm – XR77
Ignition coil – XIC8029
Volvo 340 1.7 B172
Ignition module – XE14
Condensor – n/a
Distributor cap – XD158
Rotor arm – XR159
Ignition coil –XIC8076
Lists the ignition module and ignition coil as the same for a 1.4 and 1.7…. odd!
Condensor - XCON78
Rotor arm - XR103
Contact set – XCS90
Condensor – XCON79
Rotor arm – XR104
Contact set – XCS90
Condensor – XCON79
Rotor arm – XR104
Condensor – N/A
Rotor arm – XR160
Condensor – XCON123
Rotor arm – XR77
Volvo 340 1.7 B172
Condensor – n/a
Rotor arm – XR159
Enjoy your 300s
- antiekeradio
ignitions were remapped by volvo !!
(due to volvo-specific carburettors)
I guess the info is @ Volvo Netherlands (Beesd)
the numbers of the archive sheets you want are on a paper I posted on V3C once;
greetings Wouter
Ignition system is now operating successfully
Due to a certain level of incompetence on my part this ended up involving the AA man, but this turned out to be a bit of a bonus (or maybe not).
It seems that the majority of my running problems are because my carb is generally buggered and needs a thorough refurb or replacement
At least I know the ignition parts are all working properly though
