Engine coughs
can you see anywhere to plug the hose into? try blocking the end of it. sounds like the timing is out, which could happen at high throttle if the vacume hose is missing/damaged
I have been searching place where I could put that hose, but I have not found
I try to block that tomorrow. It has been falled out few times, as other end is very exploded and it was otherway before I reversed it
Tomorrow busy day, car needs new wax, white dials and that hose fix, plenty of time to look other things for it too
- Duvel78
- Website Admin
Carb is Solex 34-34 CISAC Z11jtbo wrote:Engine is B200K later version, not sure about that. Carb is newer solex, is that z11 or something.
It could be possible to find a good plan of the carb!
V3M for life!
V3M for life!
look on the top of the crankcase, and the other side of the carb, for somewhere to put that hose.
I have few plan images from carb, are these right ones?
http://www.janiervast.com/bpa/albums/vo ... cisac1.gif
http://www.janiervast.com/bpa/albums/vo ... cisac2.gif
- Duvel78
- Website Admin
Yes, it seems to be the first one, here is a pic from a new one:
http://www.misab.se/13330000.htm
The price is... 370 €!
V3M for life!
V3M for life!
if someone can translate the words on there into english i might be able to help
- Duvel78
- Website Admin
5lab wrote:if someone can translate the words on there into english i might be able to help
1. carb
2. repair kit
3. screw
4. temperature compensator
5. screw
6. screw
7. filter
8. nipple
9. washer
10. washer
11. spring
12. needle valve
13. screw
14. jet
15. screw
16. mixer tube
17. mixer tube
18. injector
19. jet
20. main jet
21. cover
22. spring
23. clip
24. repair kit
25. washer
26. screw
27. spring
28. control bobin
29. spring
30. companion flange
31. spring
32. screw
33. lever
34. screw
35. adjusting screw
36. cap
37. solenoid valve
38. adjusting screw
39. spring
40. screw
41. pre-heating relay
42. cover
43. jet
44. gasket
45. lever
46. float
47. gasket
48. diaphragm kit
49. cable
50. sealing plug
51. O-ring
52. diaphragm kit
53. segment
54. repair kit
55. bracket
56. plug
57. clip
58. jet
59. valve
60. plug
V3M for life!
V3M for life!
Now I cleaned and greased that part number 4 temperature compensator. It is somekind of valve that closes when I push accelerator, but opens at idle position. It sucks air very little when at idle.
Hose is attached to it but there is nothing where to plug it in range of that hose.
However there is one copper colored plug in other side of engine, maybe 15cm from flywheel and 25-30cm from where exhaust manifold mounts. There is nothing plugged and I don't know what it is, at least it does not leak anything from there, it is good right?
Because that hose has been lose and there is vacuum in that number 4 part, it has sucked sand and dust into carb, also there is sand like stuff at top of carb on that top lid where is holes where fuel and air is mixed, sorry lost word... Anyway stuff inthere is black and like oil with sand in it.
Engine does not burn oil yet, but is it possible that my engine is soon history because of these events?
- Duvel78
- Website Admin
Try to show it on a picture...jtbo wrote: However there is one copper colored plug in other side of engine, maybe 15cm from flywheel and 25-30cm from where exhaust manifold mounts. There is nothing plugged and I don't know what it is, at least it does not leak anything from there, it is good right?
V3M for life!
V3M for life!
What I have learned from finnish forum, that copper colour part is used to take coolant out from engine and there should be hose from carb to nowhere. I might look some filter for that hose so no sand will come into carb anymore. Also there should not be vacuum, that thing needs to be looked little closer too.
- Duvel78
- Website Admin
Someone with a B200K could say if it's normal or not what we see... James? Mark?
V3M for life!
V3M for life!
