Frits
Posts: 725 Joined: 04 Jun 2006 07:58 pm
Post
by Frits » 30 May 2010 04:59 pm
Bought some parts again..
Mark III taillights..
New front window, because I demolished the old one.
Mark III tail, got it for free
Little bit work:
"new" inner arches
Some rust preventing
The rear discs
Frits
Post
by Frits » 15 Jun 2010 11:30 pm
Hydraulic handbrake
Balance brake bar with dash adjuster
main switch
Frits
Post
by Frits » 28 Jun 2010 10:32 pm
Posts: 2537 Joined: 18 May 2006 03:43 pm
Post
by MCHUDD » 29 Jun 2010 09:58 pm
Hi frits.
The body work is coming along great. Good luck.
Frits
Post
by Frits » 17 Aug 2010 10:24 pm
Posts: 9600 Joined: 18 Jun 2004 11:53 pm
Post
by Chris_C » 17 Aug 2010 11:55 pm
Good plan on the stands bud, it's something I've been thinking about for a while and meant to put in when I repaired my jacking points.
Frits
Post
by Frits » 18 Aug 2010 07:42 am
I removed the rear jacking points. I make a new design myself. Original ones are not strong enough.
Posts: 9143 Joined: 11 Nov 2008 04:22 pm
Post
by volvosneverdie » 18 Aug 2010 08:03 am
Sorry for the stupid question, but how do rally stands work?
Do they just achor on to the car then lever it up off the ground?
Frits
Post
by Frits » 18 Aug 2010 06:59 pm
Next pictures will clear things up for you.
Example
The most hufterproof safe way to work on your car at any location.
mat_91
Posts: 636 Joined: 07 Oct 2009 08:50 pm
Post
by mat_91 » 18 Aug 2010 08:26 pm
dam you beet me to it ive got plans on doing rally stands into my build over the winter but think ill make a central jacking point front and rear to jack of then slide in the stands
Frits
Post
by Frits » 21 Aug 2010 06:21 pm
For the front I want a sump protector which is strong enough so I can use it to jack up the car too. But, still need a new jack
Posts: 3657 Joined: 31 Mar 2005 09:01 pm
Post
by 340GLT » 21 Aug 2010 06:55 pm
Funny you should post the stands up, I just removed my sills and bought replacements for this very reason.
magnumpi
Posts: 1289 Joined: 05 Feb 2008 11:39 pm
Post
by magnumpi » 22 Aug 2010 01:51 pm
Next stupid question, how do you get the car that high to put the stands in? I find the 300 well sketchy to jack up as it often ends up on 3 wheels the higher it gets.
I take it they slide into strengthened mount/hole in the cill?
mat_91
Post
by mat_91 » 22 Aug 2010 06:29 pm
you make it so you can jack the front up and the back with a special jack jacking points front and back
look at videos how they do the rally cars and it will all make sense got to be the safest sort of axle stands
Frits
Post
by Frits » 13 Sep 2010 08:49 pm
The new jack points
seat mounting plates
another hole
left side
another hole :]
another hole :]
