Page 23 of 27
Re: Duchess The Volvo 340 CVT
Posted: 27 Sep 2017 10:55 pm
by JFB
Yes
Posted: 27 Sep 2017 11:35 pm
by benji1985
JFB wrote:Yes
i have kick down and rear wiper near the gear selector, so had to use the green switches for things
Posted: 08 Oct 2017 05:00 pm
by benji1985
Hello all.
So as you all know she passed the MOT, however upon driving her i was not getting much "gearing up", so some investigation was needed.
It turns out that the outer seals were not sealing and letting air in, new seal were obtained and and lot of reading later and thanks to Mac for all his help in making me understand.
20171005_211353 by
Benjamin Charlton, on Flickr
As you can see the seal feel apart
20171005_211359 by
20171005_211633 by
20171005_212212 by
20171005_212218 by
Then proceed with the other side
20171006_205649 by
Now just got to wait till i cna put them back on to the car and test her.... fingers cross
Now for some R+D, I am replicating the De-clutching servo, it is coming on quite nice
20171007_131846 by
20171007_131903 by
I will post when i have managed to test drive her
Ben
Posted: 08 Oct 2017 08:11 pm
by bogbasic
Awesome work.
Posted: 20 Oct 2017 01:51 pm
by benji1985
Good day all, Well today is a good day, managed to get the repaired parts back on the car.
17/10/2017
With the repaired parts fitted back to the car and tested the vacuum on both sides at the drum and the 4 way vac valve, she is now holding vacuum.
So time for her first proper outing, just a short trip across the moors as it was raining.
20171017_174523 by
20171017_174529 by
20171017_174535 by
20171017_174549 by
20171017_174559 by
I can confirm that the new seals have helped a lot, however there is still an upgearing issue, so going to test the electronic side of things.
Will keep you posted.
Ben
Posted: 20 Oct 2017 06:29 pm
Looks awesome Ben! Must have been a great drive.
Posted: 20 Oct 2017 06:35 pm
by 360beast
Good to see it out on the road
The passenger headlight wiper is messing with my brain haha.
Posted: 21 Oct 2017 01:58 am
by bogbasic
Awesome work, epic and evil. Are you sure its got enough of that 'new car' feel ;-?
Posted: 21 Oct 2017 08:31 am
by benji1985
360beast wrote:Good to see it out on the road
Yep i'll fix that, i'll be honest i didnt really notice that, there are still a few little bits that need to be sorted.
Posted: 21 Oct 2017 08:32 am
by benji1985
bogbasic wrote:Awesome work, epic and evil. Are you sure its got enough of that 'new car' feel ;-?
I wouldnt say "new car" but does feel good, she a little "go-kart"
Ben
Posted: 21 Oct 2017 11:45 pm
Who needs new cars when you can make them yourself
Posted: 22 Oct 2017 07:29 pm
by MCHUDD
Posted: 22 Oct 2017 07:54 pm
by benji1985
Thank you
I am quite proud of myself, still have a few little things to do but they have to wait, need to sort out why she is not upgearing quite right, working through the fault guide from mac atm.
Can't wait to have her at a show, soon I hope.
Ben
Posted: 22 Oct 2017 11:55 pm
by bogbasic
I can only second Mark's comments, but I wonder what else he thought at the meeting.
Posted: 06 Nov 2017 08:02 pm
by benji1985
Hello all
02/11/2017
I am please to say that i finally found the problem with my up gearing with thanks to Mac, and James. the transistor in the black box was replaced which saw the solenoid click at 1800rpm or greater, so she went on a quick drive.
this is a video!!
20171102_124913 by
20171102_124954 by
20171102_125024 by
20171102_125047 by
20171102_125055 by
However she was not up gearing still, so headed back and tested the vacuum, there was a small vacuum so decided to try the other 4 way valve I had, this yielded a much greater vacuum, and now while driving along if i hit the low hold switch the revs ramp up and then down after the switch is turned off. So it would seem that all aspects of the CVT were at fault, the seals in the drums, the 4 way valve and the black box. However i am glad to say that she is now driving at last, the belts still need tensioned correctly and the de-clutching servo needs adjustment along with maybe the clutch shims.
this is a video!!
20171102_132358 by
20171102_132551 by
20171102_132614 by
20171102_132618 by
20171102_132625 by
20171102_132639 by
20171102_132654 by
20171102_132704 by
