Trallas Volvo 360GLS
tralla44
Re: Trallas Volvo 360GLS
Post by tralla44 »
Ride to Live
Live to Ride
Post by MCHUDD »
Those wheels look a class act.
sm4 sm4 sm4 sm4 sm4
Post by bogbasic »
Wicked work all round. Beautiful houses but it still looks a bit nippy where you are, mate. Ta bog.
tralla44
Post by tralla44 »
Hey Guys.
Where i can find Info about this?
This part is equal with B19A and B21ET????
What frekvence is B19A??
And What frekvence is B21ET??
Maybe someone know where i can find this info ?
Ride to Live
Live to Ride
Joris
Post by Joris »
That is part of the renix system, which only came on the 300 series! B19a is carburetted with point ignition, b21et had kjet with point ignition if I'm right. I've heard that you might be able to use a cranksensor from a Volvo 440, 460 or 480. But not sure of that.
tralla44
Post by tralla44 »
I need to find sensor with 3wires.
And frekvencies is 930. Because Audi 1.8T AEB is 930frekvence.. And all wires and computer will be 1.8T AEB
Ride to Live
Live to Ride
I can't see the images but I'm guessing you are talking about the crank sensor. The 940 sensor is 3 wires but this thing is just a coil the extra wire is a shield to ground.
Also not sure what frekvence is, I know inductances have a frequency characteristic but it may not matter much. Does it mean 'turns' or 'coils'?
I'm going to wire the 300 renix crank sensor to the 940 EZK ignition unit but I'm not sure that it will work. I really don't want to modify the 360 bell housing to fit the 940 one. Worse case I will glue the 940 coil to the 360 bracket.
I do worry that the 940 is shielded because it is a smaller signal, but it should then either work or be possible to attenuate the signal from the 300 with resistance.
tralla44
Post by tralla44 »
Hey guys i have some quastions, i have B21ET engine and B23FT..
What engine will be powerfull? The B21 block i am rebuild. Maybe need block from B21ET but cylinder head from B23FT? Maybe it will give extra hp. B23FT from limousine
Ride to Live
Live to Ride
tralla44
Post by tralla44 »
mhmm i have some isues
when i put in engine and screw with gearbox.
then engine cant run.
when i am put out bolts from engine and gearbox(but engine is a right place)
then engine run
Ride to Live
Live to Ride
Sounds like the gearbox is jammed, could it be in gear?
Post by bogbasic »
Good point - could be gearbox linkage.
tralla44
Post by tralla44 »
that problem solved.
there was problem with gearbox
Ride to Live
Live to Ride
tralla44
Post by tralla44 »
Ride to Live
Live to Ride
tralla44
Post by tralla44 »
Winter is going down, then car need to going garage.
With 29 Februar Every day i will be in the garage until Mart 24.
And it will be crazy if engine will work until Mart 24.
Ride to Live
Live to Ride
