SPAX front dampers
I'm probably gonna have to say no, as I have a horrible feeling I may be doing a head gasket soon!
Carl
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
www.carlgibbs.com/gallery
But previously:
1988 Volvo 360GLT
1988 Volvo 360GLT
1984 Volvo 340DL
Re: SPAX front dampers
AS to being original we can have them made in black but you can not see tham anyway on the front as they are inside the strut.classicswede wrote:
Ok here is the YES list
Adjustables-
FoggyJames
Black_360_GLT
340 Nate
Ronnie
Chris_C?
Dai, I WILL have a set, just I can't say when at the moment. As people who've had a ride in Kar will say, the shocks have gone. AFAIK, jan/feb time will be ok for me from current predictions.
You know what its like, I don't want to f*** you over short term
Thats ok Chris I have only put you down as a ? maybe.
We will be looking at about mid feb if I put the order in early jan.
Just answer the question about how the dampers are adjustable. The are not height adjustable but bump and rebound adjustable.
A damper transfers fluid from one chamber to another. To do this there are two valves between the chambers. One is a flow ( bump ) and the other is the return ( rebound ). What happens is when you compress a damper the fluid pushes through the valve moving to the other chamber. IF you make the restrictive hole smaller it becomes harder to compress the damper and iuf made bigger it it needs less force to compress.
The rebound is where you try and pull the damper out ( this is the important part that stop's the spings bouncing up and down) the fluid flows through the return valve. The same applies to this but obviosly one a pulling force. The rebound should take more force for movment than the bump.
If anyone has missed the price we are looking about £100 each for the front and £130 for the rears as always.
- foggyjames
So £330 for the complete package? How about a few notes off if you buy them as a set...maybe a round £300?
Let me guess, the £100ea for the fronts IS with a few notes off...
The price for the fronts is what I expect they will cost me!
I'm looking here to confirm the ppl realy do want them and it is worth having them made.
I do understand that for most of us that kind of money does not come easy. If we can get enough interest it will be one big leap forward for performance 300's.
I am glad to say that the interest is there but we do need some more names.
If you are interested and think you MAYBE alble to invest in a pair put your name forward as a maybe.At least then I will know you are interested.
Black_360_GLT
- foggyjames
£130pr for the rears.
£330 for the complete set.
I'm guessing Dai knows of something available off the shelf which fits the back
- foggyjames
Learn to read340GLT wrote:i was under the impression it was £100 pair!!!
- 340GLT
In an old thread i swear it said they would be £100 not £100 a pair anyways. I'm unsure on this one at the mo, have to consult the finance situation after christmas, i have tax and MOT to pay for aswell as the body work!!!
Cheers Adam
