Sorry dude, I will make sure I play and get some in! Actually, Andy Pettaw came up with some good points when he came round last weekend and had a play, I'll get him to put some up too!
Now it is possible to test my Volvomod for rFactor
Ive done all the poly reduction to the model now, but there are still some panel gaps at the front that you can see through. I'll be clearing them up in the next day or two redy to send to you.
I see you kept my textures in seperate files, but I see most cars have nearly all textures on one sheet. Would it be alright if I set up a new texture sheet and apply it ready for your next version
Downloading this as we speak
Thanks again for getting her in there
Yes, for bumper I have been thinking that I get new photo to use as texture, I took one day over 300 photos from car for textures, all is from interior however, but my bumpers have been developed certain level of grayness lately so can't use those.
Maybe I find some photo from interior to use as it really does not need to be much special, just black with small bumps in it, like steeringwheel center area.
I would need to take more photos from interior as there is lot of shine and reflections, it was bright sunny day, cloudy day might be better to start with.
Also headlights and front blinkers might use new texture, must try that one, but I think I need to make some kind of mask from paper so that reflections would be neutral, have to think about that, I'm not very good in photographing yet, but that I will learn too now
Also I need to think about GLT and GL Injection bumpers as those are colour coded as are mirrors too and how am I going to get those work properly in game.
Then also comes hatchback 3dr and 5dr models and there is some issues too to be solved.
If you look close this latest version you can see how other side tyres are installed wrong way to wheel, tire thread goes wrong way, I was bit lazy with mapping on that
I have used so far texture named black.dds for black parts, but that is going to change, every texture and part must be named unique, if track has texture black.dds game uses car or track texture, impossible to know which, so need to name those and make final textures and then do mapping.
I can send it then back to you when I get it to enough ready state so you can make re-mapping if needed, I lack few skills to make mapping 100% right I'm sure
Oh yes, forgot to mention, you need to remove old volvo folder from gamedata before you install this latest, otherwise it may use wrong files or something...
Personally I wouldn't use photos. They're very good for low poly models to look better, but when moddeled well, painted textures are better. Look in the rfactor vehicles folder, say the Hammer, and you will see that flat colours are used (but perhaps with darker shades lower to give a shaoddow impression. This is because the games engine can apply reflections, shadows etc.
I would create a section of bumper, perhaps using a pic as a basis and just stretch it out. Then for colour coded, the grey bits in the texture file will be changed. Therefore to get colour coded bumpers you just choose a new skin
I'd be happy to do some of this, but if you'd like to, go ahead. As for the indicators, I rather like mine
Took me a while to photoshop a front and side together so it wrapped around. I plan to get some new tyre images of propper Mitchilins. Perhaps I could use the one under the bonnet as it's original
As for hatch/saloon etc, I need to drop you a PM about this.
Theres a welded diff....!?!?? Presses download button...
It is as much welded as I quickly was able to make, it really is viscous coupling with 100% power to left and right rear wheel so it is not quite welded because of that, I will look if it is possible make lock even better as now it requires bit slide to work out.Chris_C wrote:Theres a welded diff....!?!?? Presses download button...
I havn't got to download that last one and have a test yet! Working at a rate of knots Jani
Or I might be getting slightly lazy...
Right, download it now, and will have a test either tonight or tomorrow!
I still havn't had a chance to have a play.. sorry about that dude! Looking good with the new one though!
