Derrick the Volvo! Update P47
jon-ovlov
Re: Derrick the Volvo! (pic heavy p3)
Post by jon-ovlov »
Cheers VND, i'll check it out tomorrow. :D
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Good luck man. Hope it is something simple.
Do a search for "carb base warp" for more info. possibly "air leak" too.
Theyve both been covered by better men than me. :wink:
valman
Post by valman »
jon-ovlov wrote:Cheers VND, i'll check it out tomorrow. :D
Odd... mine just started doing this today too... and incidently will also be checking it tomorrow haha! good luck with your fix bud
jon-ovlov
Post by jon-ovlov »
AH HA! Snapped idle solenoid connection, simple solder job. No idea how it happened mind, though looking at it, its bloody fragile! Hopefully that'll solve the missfire problemo.
QR boss is fitted and working well, need to wire up the horn, and hopefully Dai's lowering kit etc will turn up tomorrow too! Just wish it was warmer!
Rev engine to 7K
Win at life.
Post by volvodspec »
VND's guess wasn't farr off, as a airleak will also "solve" itself if you pull the choke out a bit.
glad it's sorted
Good news dude. Simple fixes rock.
jon-ovlov
Post by jon-ovlov »
volvodspec wrote:VND's guess wasn't farr off, as a airleak will also "solve" itself if you pull the choke out a bit.
glad it's sorted
Aye, was around the carb anyway!
volvosneverdie wrote:Good news dude. Simple fixes rock.
Amen! Awsome.
Rev engine to 7K
Win at life.
jon-ovlov
Post by jon-ovlov »
Received the bits I ordered off dai today! :D Only got one block fitted though. 26 years of rust, dirt and grime tests your strength and patience! And of course, your hands end up like this:
Tomorrow sees the rest of the lowering kit going on and the ARB link kit. was in uber need of the link kit, the rubber bushes may as well not be there.
Blocks -2" and ARB kit
190lb springs -3"
Block fitted!
Oh, and also the re-soldering of the idle solenoid'll be done tomorrow too. :mrgreen:
Rev engine to 7K
Win at life.
Good effort! But please tell me there's an axle stand somewhere hidden in that last pic :shock:
jon-ovlov
Post by jon-ovlov »
yes there is, just off cam to the right. The jack is just low enough to get in and out. its not resting on it! :D
Rev engine to 7K
Win at life.
theo2468
Post by theo2468 »
done it yet?
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
jon-ovlov
Post by jon-ovlov »
theo2468 wrote:done it yet?
Aye Lad! Looks sweet, though a lil weird, as i have the super stretched tyres on the back atm, and 55 profiles on the front, so laid back a tad! i'm gonna swap the wheels over tomorrow and take some pics. He's running awsomely at the mo too, sorted the carb issue, and tested out the new springs. I swear their not -3" though! :lol:
One thing to note, is as i was swapping the springs over, i found both front shocks had collapsed as well. It doesnt bounce around alot, though the lower height has hightlighted the issue a little. Another thing to do!
Got the F7R engine hopefully sunday, and have begun aquiring bits for the engine swap. Braided hose for the catch tank and connectors ordered, and I'm going to bend back the other pair of banded steels, so I'll have matching wheels! (hence why they were £50!)
So, pictures: I got eaten, mate Alex helped here! :lol:
Difference in heights
Mate John helped the next day. ended up being a corner a day. Bloomin bolts.
ARB link. No more play in the anti-roll bar now!
Cheers to Dai for all the chassis bits.
Hopefully some full car shots tomorrow! :mrgreen:
Rev engine to 7K
Win at life.
theo2468
Post by theo2468 »
How long are the bolts which come with the blocks? As I've just won some off the bay and they dont come with bolts.
Cheers theo
Evoman
Post by Evoman »
shweet looking 300 :D
jon-ovlov
Post by jon-ovlov »
Evoman wrote:shweet looking 300 :D
Cheers for that!
Couple of 1.7 bits turned up today for the conversion.
clutch, and clutch cable.
Also managed to get the door seals done, finally! Old ones were like brittle plastic.
Once it stops raining, i'll try and get some more pictures done. :D
Rev engine to 7K
Win at life.
