Trallas Volvo 360GLS
tralla44
Re: Trallas Volvo 360GLS
Post by tralla44 »
Hey guys,
Maybe you can help me with this??
What is this?
Where is yellow ringles.
Picture not mine.
The waste gate can be in exhaust side?
There will not bee too hot?
Ride to Live
Live to Ride
ralf850gle
Post by ralf850gle »
Hi,
okay, the right one is an electrical engine heater.
In Sweden quite normal. Made by Kalix.
Completed with a special cable which ends in the grill or bumper and a power cable to connect to ac.
The left one should be a coolant drain plug.
Regards
Ralf
tralla44
Post by tralla44 »
Thnx mate for anserw
So if i right then this right
I don,t need yes?? IF he is only in winter make engine hot. (If i am understand right)
And left if i am right.. then i can plug into in that tube where from water pump in that tube yes??
Ride to Live
Live to Ride
ralf850gle
Hi,
the right one ok - ignore it, if you don't need a warm car from start up in winter...
But why you want to connect the drain plug (for empty cooling water when you exchange it) with
the water pump ?
Regards
Ralf
Not sure what you mean about waste gate. The waste gate is inside the turbo and has to be in the hot exhaust, the waste gate actuator is the blue thing on your engine it controls the wastegate according to pressure in the inlet side to ensure a fixed pressure.
tralla44
Post by tralla44 »
Because, from water pump i have thi pipe.
And i was thinking maybe i need to plug.
Or just need to close this tube and block dry hall..
About wastegate.
That vakum pump i just wanna move to exhaust side.
Because if i have in the cold side it,s not working because engine mounting :)
And maybe someone can hel me with Turbo Oil??
Where it need to plug? I just cant find some pics..
Ride to Live
Live to Ride
The pipe is the oil cooler version, the downwards pipe connects to a water-oil cooler, the water the returns by the drain valve position. The oil filter is on long adaptor thing that brings the oil cooler and filter beside the water feed+return. This is how the 940 turbo works.
The 940 turbo has an oil feed for the turbo the block face and a different engine mount.
The 360 heater pipe has no joint here so you could use one of those.
tralla44
Post by tralla44 »
Maybe some ome wanna bought from me my volvo 360
I don,t have any time for him.
Engine Block from B21Et Head from B230FT Turbo garret
Cluch komplekt new sachs 228mm
Flywheel lighter 1.8kg lighter than original.
To get this Project done. All is need a time for repair.
All details to have done this car i have. Just need to work. But i don,t have anymore time for her.
Still i will give you Facelift lights, Another gearbox, facelift front bumper. LPG 4generation for 200Hp
R15 RH wheels
R13 wheels for winter with tires.
Subwoofer aktivni + Pionner tv navigation and more .
Price is only 750Eur
tralla44@inbox.lv
Ride to Live
Live to Ride
