..update
Lookin' awesome! Thought about posting it on Turbobricks?
The VOC are hosting 'the National' / Best Kept Volvo show in a couple of weeks near Aylesbury. It's probably the biggest Volvo show in the country each year. It'd be great to see you and the car, if you're around.
Jason B
Post by Jason B »
Looks brilliant! the only suggestion I'd have is that if you want your car to run cooler, then I'd get rid of the raised bonnet near the windscreen (unless it's so the bonnet is clearing something in the engine bay) as it will be doing you no favours like that.
Keep up the good work!
Awesome, I wasn't convinced on the wheels but I do like them on the car... looks great!! :D Turbobricks people would love that thing
Post by 340GLT »
Lookin awesome mate.
Minilites look fine as long as their size is in the correct proportion to the rest of the car ;)
kaos
Post by kaos »
Jason B wrote:Looks brilliant! the only suggestion I'd have is that if you want your car to run cooler, then I'd get rid of the raised bonnet near the windscreen (unless it's so the bonnet is clearing something in the engine bay) as it will be doing you no favours like that.
raising the bonnet normaly does tend to aid cooling.
hence why some street rods have the vent by the windscreen on charger hoods. it helps pull it in due to pressure drop or something.
volvorsport
Post by volvorsport »
hmm , cams ,valves springs all need to be considered in the valve float issue aswell as the actual poundage on the seat .
all voc(volvo original cup) guys use teh std valvetrain but they obviously working to a formula .
the cam manufacturer will give you the best advice on the cam you want to run all other things being equal 6500 rpm should be fine on the stock valvetrain , and you shouldnt be revving it any higher than that to make 250 hp .
the grasstracking 8v had buckets like SpM ones with the shim under the follower to allow for a better profile with double valve springs , still , the powerband was only 7 to 7500 rpm tops .
as far as enem cams go anything peakier than a v16 needs some valvetrain work .
the only thing that prevents me from working with these cars is the torque tube , splined shaft . Its a massive cockup from volvo as far as im concerned :D
Post by redline »
foggyjames wrote:
The VOC are hosting 'the National' / Best Kept Volvo show in a couple of weeks near Aylesbury. It's probably the biggest Volvo show in the country each year. James
can you post details of this in the calender section please James
It's already there Mick!
Jason B
Post by Jason B »
I have fairly modest NA power goals... about 160ish bhp, I have an H-cam (more for the fact that its a bit rare than power) will probably be upping the scr a bit along with some port matching and hopefully megasquirt to fuel and spark it. Also will be running a 2.5" exhaust as it can free up about another 8-10bhp from looking at the differences between b230fb's and b230fx's. Obviously it will be revved as required to keep making the torquez until it comes off cam :D
@kaos - sadly this is a bit of a car myth, you'll more than likely create a flow stall at the bonnet/windscreen interface and basically stop air flowing across the radiator. I've not looked at big streetrod scoops and how they work, but certainly for raising the back edge of the bonnet it wont do you any good. An easy test is to have the back edge raised and stick some bits of wool to it and then go for a drive. If I'm right it will probably get sucked under the bonnet at higher speeds. Here is a basic pic, the red bits are higher pressure regions.
Ozbrick
Post by Ozbrick »
Glad to see a fast full fat (5 door) 360! There's hope for mine yet!!
1985 - Volvo 360 GLT - V3M downunder! Uprated coils and leafs, Gas shocks, 3A Racing Filter + balls!
2002 - Renault Clio Sport - http://www.ozrenaultsport.com/forum/vie ... php?t=7697
Jason B
Post by Jason B »
lol, there really isn't that much difference at all between the weights of the different models. Just the 3dr looks a little nicer than the 5dr imo (though the saloon is the best ;)).
xtrmjks
Post by xtrmjks »
Thanks people!! I'm working on some running gear changes(gearbox, diff..) and THEN it can be "wound up"!!! :wink:
Jason B
Post by Jason B »
do tell.....
xtrmjks
Post by xtrmjks »
I have few options I'm looking at..trying to document development on this, so "next guy" can use it. Open to ideas!! Your opinion wanted! :wink:
also, alloy tank/swirl pot set up goin in soon..and new suspension..etc.
