Evoman's 360 GLT
Re: New member, 360 glt
i thought dai sold spax? Id want something alittle firmer than the current i think
- trabitom99
Make sure they're 360 struts, not 340 ones ... 360 struts have the added bracket for the "stabilisers" or "link rods" or whatever they're called:Evoman wrote:Well my plan is to get 2 glt stuts off theo if he is correct in remmbering he has some. Then try some 40mm lowering springs on them depending on price. what you guys do?
I heard it was just the glts? but i suppose i still have different ones to 340s
both my struts have that bracket i think, but in different directions of 90 degrees. The important thing is that one is longer than the other
- trabitom99
All 360s have that bracket, all GLTs had shorter springs
Some late 340s may have been equipped with 360-style struts (with bracket) but I wouldn't count on it.
GLT's had bigger struts aswellEvoman wrote:so i could have a 360 strut on one side, and a glt one on the other side?
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
Well the insert, not the actual strut so all you need is the insert I think
ye, i definetly need a bigger strut. Im sorry to be thick but what do you mean by the strut insert?
I don't know how to explain it someone bail me outEvoman wrote:ye, i definetly need a bigger strut. Im sorry to be thick but what do you mean by the strut insert?
The "shock insert"(absorber) goes inside the fixed "strut", then the "spring" is inserted over both into the top mount.theo2468 wrote:I don't know how to explain it someone bail me outEvoman wrote:ye, i definetly need a bigger strut. Im sorry to be thick but what do you mean by the strut insert?
so by the strut insert your reffering to the body? with which the srping and shock are on?
Actually, Mebeez. The "strut insert" is like the "front shock" that "inserts" inside the front strut housing (front strut).Evoman wrote:so by the strut insert your reffering to the body? with which the srping and shock are on?
That's itvolvosneverdie wrote:Actually, Mebeez. The "strut insert" is like the "front shock" that "inserts" inside the front strut housing (front strut).Evoman wrote:so by the strut insert your reffering to the body? with which the srping and shock are on?
oh right just the shock then? lol! theo anyideas if you have glt struts? or inserts?
Im guessing he has struts, but not inserts (shocks)Evoman wrote:oh right just the shock then? lol! theo anyideas if you have glt struts? or inserts?
