Page 6 of 6
Posted: 30 May 2006 09:22 am
Awesome work mate - I'm sure it'll stop as good as it all looks!
Posted: 30 May 2006 08:20 pm
by 340GLT
Right update time, the brakes are nearly bedded in now and i am getting a good feel of the pedal now.
When i first set it all up and took it out the brakes were spongy but it would still lock up a front wheel at low speed!!
In total the brakes have been bled 5 times!!
At speed the brakes dont need to be used past half pedal otherwise the braking is to heavy, it slows down very rapidly and at low speeds like 5mph, on tarmac it WILL lock both fronts if you jab the pedal!!
They will need minor adjustment and i want the handbrake to lock up, but i will need more of the pad surface worn on the back before i can adjust them up.
I feel its a very acomplished setup and am very pleased with the results!! I definatley recommend something for those of you going to stupid power!!
As for the suspension thats pretty gud too now, i chucked it round a tight bend on the way back from work and she was nearly totally level, just turned straight in!!
Posted: 01 Jun 2006 05:22 pm
by 340cbr
Do you have some brake distances to compare?
But the best in your brakes is that they will not become hot as quickly as the standard ones...
Posted: 03 Jun 2006 07:37 am
by SoLaMaNdA
Wow, very very very trick. That is something I'd love to do to my car! Can I have a go and see if I can get them to fade?
Posted: 16 Jul 2006 07:53 pm
by Gulbrandsen_Racing
hmm, i love this.. you wouldnt make me some brackets, so i just can bolt it on to my car?
I'm wondering on 5-link too.. Get it approved, and legal on the road..
Posted: 16 Jul 2006 09:28 pm
by 340GLT
Gulbrandsen_Racing wrote:hmm, i love this.. you wouldnt make me some brackets, so i just can bolt it on to my car?
I'm afraid its not as easy as that!!!
Posted: 16 Jul 2006 11:57 pm
make it easy! There's nothing that money can't buy..
Posted: 17 Jul 2006 12:00 pm
by 340GLT
What i mean is even if i did just make you the brackets thats not all you would need, the hubs have to be machined and thread inserts put into the strut!!!
Posted: 17 Jul 2006 10:47 pm
Oh, i see.. Well well, i'll just have to buy third-party brake discs then..
Posted: 10 Sep 2007 11:23 pm
by alistairolsen
need gen
adaptor plates look simple enough if youd be prepared to shre the dimensions. Whats the story with the spacers between the adaptor plates and the caliper? Just smooth bore thickwall tube effectively? The inserts you refer to, are these in the original mounting bosses?
Many thanks.
