Another one..
Re: Another one..
I do have some cams! Do you know what profile you want?
Need pics of the manifold inplace and video with sound would be cool.
Jason B
Re: Another one..
Post by Jason B »
I have a D cam and an H cam, though the price would have to be right for the H-cam as it was hard to track down for a sensible price (I got it when the US-UK exchange rate was massively in our favour) and I wouldn't want to do it again.
xtrmjks
Re: Another one..
Post by xtrmjks »
Jason B wrote:I have a D cam and an H cam, though the price would have to be right for the H-cam as it was hard to track down for a sensible price (I got it when the US-UK exchange rate was massively in our favour) and I wouldn't want to do it again.
PM SENT!! :wink:
garth
Re: Another one..
Post by garth »
Stunning! Are you the chap who had the turbo'd white one in practical performance?
xtrmjks
Re: Another one..
Post by xtrmjks »
That's me! :D
Daily is all build, just need brakes bleeding..should be on road by weekend! :wink:
xtrmjks
Re: Another one..
Post by xtrmjks »
Had first "test run" today.. :D :D :D :D
Bled brakes, but pedal still bites close to floor :? No air in system and new master cylinder :(
Haynes manual says that ignition timing can not be adjusted with renix, is this true?
Re: Another one..
xtrmjks wrote:Had first "test run" today.. :D :D :D :D
Bleed rear brakes, might need to put one corner up to help air come out, I had that. Do you have compressed air bleeding device? If not take one tyre valve and put that to brake fluid tank cap, add very little of pressure and remember to top it often, helps massively with bleeding. Rear brakes can be problem as there is only one bleed nipple, but I guess you did put some other calipers into yours, so don't know if that applies now, good luck :mrgreen:
Renix ignition can't be adjusted. Well, you can get 1-2 degrees by making TDC sensor bolt holes oval or even making some adaptor to that, also you can play with vacuum hose if it gives too much advance just clamp it and it should help a bit.
But perhaps simpliest/easiest might be B19E Bosch module and dizzy+coil, then you could adjust it and spark would be bit stronger as Renix weakens spark on low load.
xtrmjks
Re: Another one..
Post by xtrmjks »
I have all new brake pipes and brakes. Swapped 240 calipers from dual circuit to single..
Brakes work, pedal just bites low down. I have pressure bled them. :?
Re: Another one..
xtrmjks wrote:I have all new brake pipes and brakes. Swapped 240 calipers from dual circuit to single..
Could it be that fluid volume of brake master cylinder is not enough for all those pistons in calipers? It can move only certain amount of fluid and if pistons need to move more than originally, that could cause some issues, but this is just a wild guess.
Re: Another one..
jtbo wrote:Could it be that fluid volume of brake master cylinder is not enough for all those pistons in calipers? It can move only certain amount of fluid and if pistons need to move more than originally, that could cause some issues, but this is just a wild guess.
I'd say that is more than likely, stock master cylinder with the amount of brakes thats been added is going to be having issues to move enough liquid!
Re: Another one..
Post by 340GLT »
That is pretty much wht mine are like mate, they bite absolutely fine, you just have to get used to it, i am looking into a larger master soon.
Re: Another one..
Twin MC bias peddle box... you know 'tis the only way!
Re: Another one..
240 calipers can have issues with air locking. Have you fully bled each nipple in turn?
Re: Another one..
classicswede wrote:240 calipers can have issues with air locking. Have you fully bled each nipple in turn?
Ha ha ha...............
Nipple.
Re: Another one..
Nipple.
And to add to your exitment they have 3 each :lol:
