Saint Giles. MOT of Win! 20.08.09
whiskeyonesix
Re: Saint Giles. Good News 14.08.09
Those darkened lenses really do the trick on that - go so well with the colour of the car.
Top marks!
Top marks!
Mods: custom paint fade
New Cylinder head.
Auxilary cooling fan.
Vario Vents FTW
G8 4 DRFTN etc....
New Cylinder head.
Vario Vents FTW
G8 4 DRFTN etc....
Cheers dude.whiskeyonesix wrote:Those darkened lenses really do the trick on that - go so well with the colour of the car.
Top marks!
vØlvØfreak
I drove last 'only' 5k RPM in the grey 360 in 5th gear, that's 183 km/h on the navi
good work vnd! Like the car
Cheers mate!vØlvØfreak wrote:I drove last 'only' 5k RPM in the grey 360 in 5th gear, that's 183 km/h on the navi![]()
- trabitom99
What's that on the speedo, out of interest?vØlvØfreak wrote:I drove last 'only' 5k RPM in the grey 360 in 5th gear, that's 183 km/h on the navi![]()
BTW, I hope you didn't try that in Holland
- foggyjames
Can't remember if the temp gauge should be at 40deg or -40deg with no sensor connected....but I'm guessing that it's either disconnected on the back of the cluster, or the sensor isn't attached...or something. Vacuum gauge looks to be working AOK...the needle is in the right place at idle. Phew!
It's -40 if it's not taking a current.
Bloody nice work - big respect to the Filthy one for sorting you out
John and Ron are indeed Legends.Ronnie wrote:It's -40 if it's not taking a current.
Cant thank them enough.
vØlvØfreak
speedo wasn't working, sorrytrabitom99 wrote:What's that on the speedo, out of interest?vØlvØfreak wrote:I drove last 'only' 5k RPM in the grey 360 in 5th gear, that's 183 km/h on the navi![]()
And yes, that was in The Netherlands, about were you are gonna get the airco
- trabitom99
PM'd! It was a long day ...vØlvØfreak wrote:And yes, that was in The Netherlands, about were you are gonna get the airco
By the way Ben... your aerial is on it's way to you first class
Ah cheers steve. I'll make sure it gets a good 'reception' when it lands mate.SteveP wrote:By the way Ben... your aerial is on it's way to you first class
- foggyjames
The carb ones are geared for about 160mph at 6000rpm, from memory. They're quite a bit taller than the GLTs, for sure.
The 740 is geared for 165mph on the 6500 limiter. I couldn't possibly comment on whether or not it can reach it. Except to say that it can.
volvosneverdie wrote:Ah cheers steve. I'll make sure it gets a good 'reception' when it lands mate.SteveP wrote:By the way Ben... your aerial is on it's way to you first class
160!!?foggyjames wrote:The carb ones are geared for about 160mph at 6000rpm, from memory. They're quite a bit taller than the GLTs, for sure.
Shocked face emoticon!
Isn't that 'take off' speed for most vehicles?
Good job 740s are heavy old things eh?
