Re: Nimminz' LSD GLT Daily
Posted: 28 Jan 2013 11:00 pm
Little update,
Wheel bearings still making a noise, not done anything else to it but the noise is getting worse. I'm getting to the point where i'll pay someone to do a propper job.
I just have very little time and even less motivation to work on the car. I've spent lots of hours working on it over the last year: lowering, headgasket, the diff episode, this wheel bearing. Lots of time when i should have been enjoying meself. I am now left with a car that I don't enjoy driving, i worry constantly about the cable tied gearlinkages, noises and grinding of the gearbox, if the expensive diff is ok, the wheel bearing banging at the back, the leaky radiator that makes me spend a fair few quid on coolant a week, the suspension which seems determined to rot away - lost both radius arm bush cups on both sides during the snow. It's feeling like i've put a lot of work in and the car is actually worse than before. I've driven this car on 400 mile trips, without a worry. Now going further than 5 miles from my house is a major worry and I find myself choosing to walk places rather than take the car. I'm not going to get rid of it - i cant afford to buy another car and i like this one too much. I just felt the need to write this down lol.
My problem list is as follows, in rough order of priority:
Wheelbearing - gearbox - gear linkages - leaking diff - radiator - blowing + mis-shaped exhaust - Front suspension - rusty rear chassis x-member - wheel arch rust - Leaky cold start injector - Leaky sunroof
Those are the main problems. Problem is most take up a couple of days work, require it not to rain etc. etc. It's just all a bit crap as I have no-where to work and my mechanic mates are all too busy to help. I have plans for 2.3T engines and multi link suspension, ITB's and all sorts but All the problems need fixing first. Plus my trip to europe is looking less and less likely as the list of things to fix on the car gets bigger and bigger.
I know there's no magical solution to all these problems (and this is JUST the car!) It's going to have to be lots of hard work and lying in mud and rain but i've run out of motivation at the moment as every job i do seems to go tits up.
Anyway, i got the 5x7's stuck in the parcel shelf and wired up to an amp and it works ok for me
