Fuellines from petroltank?
kloppen
Post by kloppen »
Hi
I noticed that i have a small leak from one hose to the petroltank. It is one of the two that goes out of the top back of the tank. It is the little rubberhose that goes from the tank to a metalpipe. I seen taht it leak when I have filled it very full. So my question is what this pipe is good for?
Is it important. It's the lines that comes up in the trunk, to metal pipes one slightly larger than the other. It's the biggest that I wonder what is the use for.
5lab
Post by 5lab »
only need to post once!
that tube is a breather hose - it lets air into the fuel tank as the tank empties - otherwise there would be a vacume
if it leaks then it may be the top of this tube has fallen down - it needs to go above the top of the other pipe.. otherwise there is a hole in it - 2 solutions - replace the tube, or just dont fill your tank as full :)
kloppen
Post by kloppen »
Thanks... I think the rubberbit is a bit old... 20 years... And thats why it leaks when I fill it to the top.
But there are two pipes... If I understand right, the thickest one is the breathing hose, but what is the little one?
wjp01908
Post by wjp01908 »
These pipes go to and from an expansion tank that is behind the right hand side panel in the boot.
They are notoriously dodgy on the 300 series and should be replaced with some new ones. No need to go to Volvo though, almost any motor factors will have fuel pipe and clips.
Be careful when taking the old ones out as the fittings can be a bit fragile.
May as well do the whole system while your at it - one less thing t worry about.
Will
yep, WIll's right, all the late 340 series have this tank, and the hoses that seem to be cheaply made. If you do get Volvo ones they only last about 2 years anyway, so go to Halfords, and the more expensive 'fuel injection hose' that should last for years and years.
kloppen
Post by kloppen »
But if this rubberbit fail, it's not any chanse for the engine not to get any fuel, or?
wjp01908
Post by wjp01908 »
No - a leak here will not starve the engine of fuel as this pipework does not feed the engine. If this is perished though, would you trust the more vital pipework.
A leak will fail the MOT (in the UK in any case - don`t know about your local equivalent) if found and it is wasteful and enviromentally harmful however, not to mention the risk of fire - probably only really likely if your car is garaged and fumes get to build up.
Will
