V3M Website URL Stickers *coolness content*
Posted: 16 Jul 2010 11:54 am
We havnt had a run of these for a while, and I didnt get any of the ones in the past, so here we have a short run.
Only available in white.
Exterior Application.
£3.50 each delivered
Or
x2 for £6.00 delivered (saves on stamps
Anyone interested, PM me for paypal addy.
All
Fitting Instructions:
MAKE SURE THE AREA YOURE PUTING THE DECAL ON IS CLEAN AND DRY!
1. Decal comes with application tape that is used for transfering the decal from the carrier paper to the application surface.
Before istallation lay the decal on a flat surface application tape side up and slide a squeegee (credit card) along the length to release it from the carrier paper.
The application tape is designed so that it does not adhere to the decal untill this pressure is applied, this helps prevent the decal from being damaged or peeled during transit or storage.
2. Release the application tape slowly starting from one corner. The decal should peel away from the carrier paper, still attatched to the application tape.
3. Press the decal up to the mounting surface and press the decal to the surface lightly.
4. Squeegee the back of the application tape firmly. This will transfer the decal to the mounting surface.
5. Starting form one corner, slowly peel away the application tape, if the decal comes away from the application surface repeat step 4.
Or
