renix 412 + Longh wheel studs
antoni
Post by antoni » 03 Aug 2010 09:38 pm
I have a renix number 412 lying around now, just wondered if it was of any use to anyone out there
After £25 + postage
Also have a set of subaru spec wheel studs at 63mm long, perfect for you guys running spacers or want quicker and easier wheel changes
£20 + postage
Located in manchester
Antoni
13431
Re: renix 412 + Longh wheel studs
Post by 13431 » 17 Nov 2010 03:34 pm
hey I don't supose you still have that renix do you and is it for a B14. 4E?
Volvo 360 GLT 2.0i
Volvo 340 MK2 (Donor Car)
Volvo 340 GL 1.4 Turbo project
Volvo 340 Gl 1.7 Skid Car/ Battle Wagon
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
One day I'll Buy one that works....Maybe! :)
pyro
Post by pyro » 18 Nov 2010 01:51 pm
B14.3E = 401 (not in UK)
B14.4E = 402 (from 1985 has change up indicator)
B14.4E = 412 (1987ish on) Retarded by 4 deg. to run on unleaded
i think it should be dude, but depends on year of your 340!
Ben
* Disclaimer
Mors Principium Est
13431
Post by 13431 » 19 Nov 2010 02:00 am
my :340: is an F Reg but the engine came out of a B Reg so...
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
Post by Chris_C » 19 Nov 2010 08:26 am
Take the engine code of off the engine plate and get the renix that relates to that. Has anything been changed between them, or was it a straight swap?
Early B14's I think require 98octane (they'll be a thread about whether they do or not on here somewhere) as Pyro says, a later Renix will pull the ignition 4 degrees so you'd be safe for 95.
13431
Post by 13431 » 19 Nov 2010 10:49 am
it was a straight swap and the engine number is : 002173619
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
