Outer Door Trim Removal?
Justin
Post by Justin »
I need to replace my front nearside door but was wondering how I remove the black rubber outer trim incase I need it for the replacement door if it doesnt have the same trim?
1988 340 1.4 DL
Nimminz
Re: Outer Door Trim Removal?
Post by Nimminz »
Heat gun and fishing wire, Its just held on with adhesive foam.
Then Tar remover to get rid of the sticky left behind
Are you on about the door seals or the metal bits around the windows?
Justin
Post by Justin »
The foam/rubber trim that runs along the centre of the door. I may need to replace it onto another door and was wondering what would be the best thing to stick it back on with?
1988 340 1.4 DL
Halfords trim repair foam tape does the job, just make sure everything is well cleaned and degreased before using it.
Justin
Post by Justin »
Many thanks...
1988 340 1.4 DL
