Underseal questions
Underseal questions
Here comes the short journey to get a new MOT and for part of protecting my car further I'm going to under-seal the bottom. There are some areas that are exposed down to the metal and have a slight surface rust on them. Would I be safe to sand these areas down a little, and seal straight over? Or should I apply some paint first to give it a guaranteed layer?
Also, what sort of brand should I go for? Is anything not good?
Last question; is mr MOT man going to be unhappy with the underseal?
Re: Underseal questions
I have been looking at this lately and mentioned this in the thread below which got no comments.
http://www.volvo300mania.com/forum-uk/v ... =5&t=10632
Normal underseal is not much good on old repairs as its virtually impossible to get rid of all the rust, you need something with a converter or zinc in it to reduce spread from rust+moisture in the pits.
If you want a quick and dirty repair, anything will prevent serious rust for a few years, probably best used with a rust converter. The main problem is removing layered rust trapping moisture, A drill with a rotary wire brush will not do it, you need an angle grinder or flappy disk. Wire brush on the drill is of some use to remove rust from pits.
The best solution I can see so far is Rustbuster Epoxy mastic 121, followed by a rubberised underseal (eg Dinitrol 447). Another product I have used is Rust bullet, which is a moisture curing paint that sucks out the moisture from the rust, it is guaranteed for 10 years but quite hard to paint over, although like the epoxy cures very hard. Zinga (zinc paint) is also an interesting product, but again hard to paint over and maybe doesn't adhere aswell as they claim.
Treating rust in a lasting way is quite hard I have been doing for 20+ years, most of the commonly available stuff doesn't work. I had the best success with zinc products in the early days, but quite hard to get and I want something better.
Cool, so from what I gather the 121 is actually a spray?
No you can brush it, its actually a 2 part material you have to mix so impossible for an aerosol spray can. Its not got isocyanates so you can use it at home. Just got my first delivery of it today.
