ah its now a five speed
daffodil
Post by daffodil »
right...i have put a five speed gear box in...very simple about 3 hours in total...now the thing is it came out of a 1.7 complete with diff
the ratio on the diff is higher therefor i have lost some of the accelaration time that i had
has any body done any head work IE skiming and porting....cos this is what i am going to do
skim head....20-25 thou
port...although there does not seem to be a lot of room...but ill see
later B14-4E manifold with performance exhaust
k@N filter
any coments would be most welcome...and ill let you all know the outcome
5lab
Post by 5lab »
maaan, i'd have easily outbid you on that car if i knew it was easy to put a 5speed in.. lucky sod :P
daffodil
Post by daffodil »
i new it was just to good to miss...while i had it on ramps i checked the underneath ....and i am pleased to say that there is no rust
floor sills solid as is the wheel arches and front valence
The 5 speed cars are supposed to accelerate faster - the diff ratio may be higher, but the individual gears are also lower. sm25
Were the prop shafts the same length? Important question for a number of people planning 4 > 5 speed swaps.
As for more performance...if you want it to go much faster, don't bother. Even a turbo conversion without major modification would still be slower than a 360 GLT. If you just want a subtle improvement to regain what you had before...investigate the aspiration end of things - intake, exhaust, head (incl cam). Air filters are a pretty subtle improvement. You want to be looking at a bigger carb(s), a full exhaust system, and a custom ground cam. It might be worth finding out if any different versions ever had bigger valves.
Also look into what Andries (I forget his sign-in) did using a Renault 5 Alpine engine. You're probably best off talking to Renault 5 people anyway, as they're more likely to go for engine modifications than 340 owners - as they'll have bought a higher spec one in the first place if they're looking for major improvements!
daffodil
Post by daffodil »
the propshaft may be a little longer...maybe an inch, but it still went on...i am looking to see if i can do any thing with the cylinder head and exhaust...
i have got a non turbo gordini engine which will be going in later in the year
I think that's the Alpine unit....which is your best bet.
bodejodel
Post by bodejodel »
That's a great engine!
It has got 103hp@6750rpm and 119 Nm@5000rpm of torque.
I'v got one laying about here too. Planning on puting it in the white car in my signature.
Jeroen
Bilbo
Post by Bilbo »
is it a Gordini motor ?
pretty anyway ,with lots of GO :mrgreen:
EDIT: ahh i see you said it was a Gordini..........doh
about 20 years ago in the midlle of no where(north northumberland) a r5 gordini turbo rally prepared,was trying to get up a hill covered in ice/snow....it was the sweetest thing i have ever heard-will never forget :D
daffodil
Post by daffodil »
does any one know where i can get an exhaust manifold for the gordini engine....that will fit into the 340
i think this is the only part that is going to take time and money
bodejodel
Post by bodejodel »
I am afraid you will have to have it custom built...
Jeroen
RandomHero
Post by RandomHero »
I had a website where guys welded custom exhaust manifolds together like making a microwave meal. The site was about putting a saab turbo engine in a peugeot 205. That's why they had to custom build the manifolds. If i find it again i can show it here.
Those guys will get high scores on the chav test i guess :-S
