My 340 project
Aaron_G_1988
My 340 project
Post by Aaron_G_1988 »
hi i have a 340 but the engine is no good, im thinking of puting a 1.8 8v clio engine in it on cams, also i would like to put 360 runnin gear on it as iv been told it will handle the power. the only problem is i dont no where to start. can some 1 please help
Re: My 340 project
Better off with the 16v if you're going to the trouble of fitting the 8v. 340 running gear will be fine despite what some people will tell you.
Re: My 340 project
The 360 running gear and the 16valve are not compatible.
Strength wise there is little between the 2. Just keep to the 1.7 transmission with the valver and you will be fine.
Aaron_G_1988
Re: My 340 project
Speedy88 wrote:Better off with the 16v if you're going to the trouble of fitting the 8v. 340 running gear will be fine despite what some people will tell you.
hi cheers for that. what type of trouble do you get with puting an 8v in? i wanted an 8v due to bein more reliable. if it is to much i will go 4 the 16v. iv hurd things about the prop shaft and bell housing??
cheers aaron
Aaron_G_1988
Re: My 340 project
classicswede wrote:The 360 running gear and the 16valve are not compatible.
hi cheers
oh isit how comes??
iv got a 1.4 so will i need a 1.7 gearbox??
from what iv learnt it doesnt seem to hard to do jus need engine, loom, ecu, and do the clutch and engine mounts while im there
have i missed ne thing?
cheers aaron
Re: My 340 project
The 8v will probably go in fine. My point is that for the same effort you could have 150bhp rather than just 110. Plus the noise the 16v makes is just so much more satisfying. If you have a 1.4 then you'll need all these bits off a 1.7:
Bellhousing
Clutch
Flywheel
Sump
There are also some other little niggly things that you'll need probably. If you can get the car to Swansea you could talk to Adam, he will do the work for a reasonable price. I highly recommend him :wink: He can also source you the parts that you will need, PM him (user: 340GLT)
