Seat Heaters?
Justin
Seat Heaters?
Post by Justin »
Does the rear window demister switch need to be on in order for the front seat heaters to work? For some reason only the passenger side seat heater works on my car and its only a small section near the back and not the whole seat. How would I go about checking the drivers seat heater in order to repair it? Does it have it's own fuse or could it be that there's a loose connection?
1988 340 1.4 DL
L14MNP
Re: Seat Heaters?
Post by L14MNP »
I doubt the HRW has to be on. The heating element has probably had it tbh mate. I don't have them in my GLS but they will be fused. If the passenger side works then the fuse is fine as it will control both. The side which has been used the most has failed due to wear and tear and old age IMO.
To replace them you will need to deskin the seats (I guess that's remove covers if not leather lol). The heater mats are glued to the seat foam.
As for testing, you could check for voltage and resistance at the plugs (under each seat) where they join the main body loom but I'd say as one is fucked and the other 90% gone then it's a waste of time.
STREETO WITHDRAWL
INTO BURNOUTSsince1982
Justin
Re: Seat Heaters?
Post by Justin »
Thanks, Im not gonna even bother trying to repair it as it sounds like a right ball ache to do!
1988 340 1.4 DL
Nimminz
Re: Seat Heaters?
Post by Nimminz »
My passenger one didn't work and all it was was the plug had come off the switch. Check the plugs are connected under the seats too. If mine pack in i'll be getting some aftermarket ones. They are so good in this weather
