lowering asap
Re: lowering asap
i'm pretty sure they would do!
you cant use blocks on the front because it aint a leaf spring! either gotta cut the springs, or buy nice new ones!
Re: lowering asap
This is a hard one as I dont think its ever been covered before and the forum has no search function............................
Re: lowering asap
volvosneverdie wrote:This is a hard one as I dont think its ever been covered before and the forum has no search function............................
breathe...............
Now.Isn't that better.
And relax.........
Write it in your heart.
The code of the West.
Re: lowering asap
No. I think I'll continue to comment.BRETTY BOI wrote:Sarcasm is the lowest form of wit mate. If this annoys you then don't comment
Use the search function.
Top right corner.
Says search next to it.
Re: lowering asap
POW! THWACK!volvosneverdie wrote:No. I think I'll continue to comment.BRETTY BOI wrote:Sarcasm is the lowest form of wit mate. If this annoys you then don't comment
Top right corner.
yes the blocks will fit. not sure bout the bolts. the ones with escorst come with U-bolts. I know that Dai's ones come with straight bolts.
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Re: lowering asap
I put "escort lowering blocks" in the search window and pressed enter.
1st result:
1st result:
Lincoln wrote:
Just need to get my hand onto the the Blocks,U bolts springs to make it lower.
Ford Escort blocks will do on the back if you file off the top locating nipple.
U-bolts are no good as the back axles the wrong shape. 4 high tensile straight bolts each side is what you need.
Could always just chop the front springs?
Re: lowering asap
AH HA! So i thought!
u bolts dont fit!
Rev engine to 7K
Win at life.
Re: lowering asap
BRETTY BOI wrote:your sad keep commenting. Thanks to everyone else for the help. And why would you go to the extent of searching it yourself don't you have anything better to do you skank
NO he searched it to prove to you it takes a few minutes to find what you were looking for.
And any need for the skank bit?
first time ive ever seen someone (try)to insult another member on here
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
- volvodspec
Re: lowering asap
hmm, if i were a moderator on this board, bretty boi would've been banned after such a response
disregarding a forum's search function is one thing, but insulting other members with big keyboard-balls is just lame. grow up
i think this might have an effect for you in the future, next time you need to know something about a 300 and post a topic here.
Re: lowering asap
yarp, comments like that will just turn people against you. I dunno, kids today, expect everything on a plate etc etc
- Duvel78
- Website Admin
Re: lowering asap
Member is banned. Reason: inappropriate comments, danger for the friendly atmosphere of the board
V3M for life!
V3M for life!
Re: lowering asap
Duvel78 wrote:Member is banned. Reason: inappropriate comments, danger for the friendly atmosphere of the board
good good
Re: lowering asap
Could he not have just stood on the naughty step for a while.
Re: lowering asap
Thats a shame.
I shall try to be less sarchastic and helpful in the future.
Whats a skank?
Re: lowering asap
1: Poverty stricken layabout.
2: a slag
3: a type of dance suitable for reggae and rude boy (madness. the jam etc)
2: a slag
