Air filter for 360 GLT
kelvingenders
Post by kelvingenders »
I'm thinking of buying a K &N air filter. How good are they when compared to a after market normal one?
Will this make the car run any better?
Kelvin - Brisbane :360:
Re: Air filter for 360 GLT
Will make your car louder :lol: May induce carb freezing but I don't think you'll have that problem in ol' oz
kelvingenders
It's for a 360 GLT which runs injectors = B200EA
theo2468
Post by theo2468 »
Speedy88 wrote:Will make your car louder :lol: May induce carb freezing but I don't think you'll have that problem in ol' oz
It's an injection engine
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
whiskeyonesix
Post by whiskeyonesix »
Air Filters? Blimey, welcome to my world! I think with the K+N kits you'll have to blank off the EGR pipework. Pipercross do direct replacement panel filters, I'm going to ask about one next week for mine.
The last car I had with a K+N kit on it, was my RangeRover classic, I don't think it made one bit of different to the economy or performance, but it sure as hell made it sound better :)
Mods: custom paint fade
New Cylinder head.
Auxilary cooling fan.
Vario Vents FTW
G8 4 DRFTN etc....
I flailed.
I flailed.
Was only a little un mate.
Nimminz
Post by Nimminz »
Air filters have always been an interest of mine, not that i know much about them. Te peugeot forum i was on was allways buzzing with the topic of are they better, do they use much more fuel, which sounds the best.
In my experience:
-they do use more fuel, that was on the little 206 though. i found on the volvo i was putting my foot down a lot more to make it growl, thus using more - who knows was also something about giving the MAF incorrect readings so it pumped in more fuel.
- Best system to get would be an 'enclosed' filter where it sucks the air from the front of the car, puts it through a filter (basically a filter in a little airbox) then goes on to the engine. its better due to the fact you suck in more dense cold air rather than hot air out the engine bay
-They all make a noise, i found pipercross one suited my peugeot best.
- There is very little difference between brands
- Foam ones are easier to clean
- performance panel filters are probably the best all round, less noise though
-possible quicker throttle response
But saying all that, if i wasnt worried it would make me use more petrol, I'd go for a pipercross or raid HP foam cone filter with a cold air feed and possible make a heat shield and get some nice shiney tubing. Just because it looks good and in my experience sounds slightly better than the rest.
As yours has the EGR you could either blank it off or some filters come with a little tube usually used for an crank case oil breather that vents oil fumes into the intake to be burnt. The EGR tubing could be plugged into that.
Hope that hels mate
Matt
I had a K&N style filter on my old 360 and took it off... the induction noise was never pleasant enough to warrant the racket, and I certainly couldn't feel any difference in performance. The standard airfilter was used in early factory 240 turbos so I doubt it's restrictive! You might be best getting a drop in replacement filter in the standard airbox if anything, it'll pay for itself in 3 services since it'll only need re-oiling
sven360
Post by sven360 »
I agree with Steve P you lose the ram effect of std airbox by going to a cone as well.
Write it in your heart.
The code of the West.
Post by filthyjohn »
I noticed a drop in torque when I swapped to a cone on my first GLT. If anything's restrictive it'll be the stone age airflow meter!
