Cheers Adam
Fan/Heater has Died!!!!! Help please?
- 340GLT
Hi i was driving along earlier and turned the heater on full, at first it was fine then it just totally died on me and now nothing will come from it!!! Any ideas people? It doesnt work on any speed!!
Cheers Adam
Cheers Adam
Its the little overheat resistor on the resistor pack. You need to remove the heater box assembly under the bonnet. Once the box is removed, separate the two halves by prizing the spring clips, careful not to lose any, they can ping anywhere.
The resistor pack is then self evident. There is a little bimetallic strip that's designed to cut the power to the fan if the coil pack overheats to prevent fire, its probably either corroded or soft and has bent out of contact, so clean with contact cleaner and if necessary bend very gently back into postion.
Hope that helps
Andy
Hope that helps
Andy
- RandomHero
This seems to be a very common problem. I see people (including myself) everywhere having this problem. Mine came back alive the same way it 'died'. It's still working ever since. I think it's pretty weird.
It may have something to do with the big fuse in the radiator house. Could be a bad contact with the wires, or it needs to be replaced.
- 360 GLT, 1989, Gray Metallic, 115.500 km, PAS, Electric Sunroof, Windows and Mirrors
- RandomHero
Ok, that's a better description from Pettaw. Was replying at the same time
I know a dutch guy who has the story of the quest for this fuse on his site with photos. If it doesn't sort out i could try to translate it for you.
- RandomHero
