360 nose dive
Evoman
360 nose dive
Post by Evoman »
When i push it into corners my 360 seems to nose dive, especailly under abit of breaking. Its rubbing on the top of the arch. The dampers seems fine any ideas?
Re: 360 nose dive
:shock:
Both sides? Sounds like something is catastrophically wrong IE something isn't attached to something else. Does everything look normal? Springs in the right place, dampers still bolted to the struts etc? Sub frame still bolted on? :lol:
Evoman
Re: 360 nose dive
Post by Evoman »
na just one side. this is one very up and down rounds with uphill corners, proper lumpy back grounds in the moutain. Im pretty sure everything is bolted one. Theres no other signs of things wrong
Re: 360 nose dive
You probably gotta take out the strut and strip it down. The top parts can get in a mess, they need replacing every 5-10 years or so especially if you give it a hard time.
Evoman
Re: 360 nose dive
Post by Evoman »
Prolem found, one strut is bigger than the other. The nearside on is an inch shorter. Does anyone know why? were 360 glts struts a different length to other 300s?
so im now looking for some struts that match
Re: 360 nose dive
ehwha? Sounds like a worn spring to me. How do you mean the strut is shorter? Pic?
theo2468
Re: 360 nose dive
Post by theo2468 »
Yeah the GLT had bigger front struts think I might have a few down at my other garage
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
jon-ovlov
Re: 360 nose dive
Post by jon-ovlov »
Evoman wrote:Prolem found, one strut is bigger than the other. The nearside on is an inch shorter. Does anyone know why? were 360 glts struts a different length to other 300s?
WTF? random. not collapsed then? Excuse to get some adjustable ones off Dai :wink:
Sorry, im in a suspension awsomeness mood. :lol:
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
Evoman
Re: 360 nose dive
Post by Evoman »
id love to if i can find the money, i think ill get some lowering springs off him
Re: 360 nose dive
Post by trabitom99 »
I guess a spring cup failed at some point, and the whole strut was replaced with one from another car. Non-GLT struts will be shorter as the springs are shorter. There is a difference between 340 and 360 struts too, 360 "legs" have an extra hole for stabiliser bars (not sure if that's the correct word for it).
Evoman
Re: 360 nose dive
Post by Evoman »
thank you, im planning on finding a glt strut. Can i put lowering springs straight on?
