13431
Posts: 196 Joined: 17 Nov 2010 03:31 pm
Post
by 13431 » 30 Jan 2011 02:11 pm
I have a
2L injection and the shaft that connects the prop to the box (female housing) is broken
If you have a gearbox and your local i can arrange pick up if not i'll have to find a way.
cheers Adam.
Volvo 360 GLT 2.0i
Volvo 340 MK2 (Donor Car)
Volvo 340 GL 1.4 Turbo project
Volvo 340 Gl 1.7 Skid Car/ Battle Wagon
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
One day I'll Buy one that works....Maybe!
13431
Post
by 13431 » 01 Feb 2011 07:55 pm
Bump
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
13431
Post
by 13431 » 01 Feb 2011 08:16 pm
I need a box soon guys don
t mind where from as long as it fits.
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
13431
Post
by 13431 » 07 Feb 2011 09:51 pm
Bump
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
Jos360
Posts: 181 Joined: 14 Jun 2008 10:31 pm
Post
by Jos360 » 08 Feb 2011 12:43 pm
Are you sure it's not just the coupling that is broken? These things break all the time and i've never heard of a gearbox breaking. The coupling is about 6" in front of the gearbox, you can see it through 2 holes in the torque tube which are closed by rubbers. Changing the coupling requires removing of the gearbox. You might as well start removing it and check if it's just that.
Unless you already did that, then I didn't say anything.
13431
Post
by 13431 » 12 Feb 2011 02:43 pm
what happend was i pulled away rather quick and i just lost all drive to the wheels.
we jacked it up and turned the flywheel and the prop turned but the wheels didn't, took the rubber bungs out of the prop and smoke came out. im really stuck and im not sure exactly what it is but my mate said it was most likely the gearbox. i live in basildon essex if somone could help me out i would be very greatful.
cheers.
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
13431
Post
by 13431 » 17 Feb 2011 07:47 pm
BIG BUMP!!
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
Posts: 2693 Joined: 12 Sep 2006 09:07 pm
Post
by filthyjohn » 18 Feb 2011 11:28 am
I have one, is 250 miles too far though? I can put it on a half pallet for a courier.
Post
by 13431 » 18 Feb 2011 03:17 pm
could you find out how much it would be to send and how much you want?
Adam.
Volvo 360 GLT 2.0i
Volvo 850 2.0 - 20V
Volvo 460 SI 1.8
