B19 VS B200
B19 VS B200
What are the diffrences between the 2 engines? Could i swap over B200 injection on a B19 or will i lose some power over the 1,0?
764 Turbo 86'|Volvo 144 72|Volvo 360 86'||Volvo 360 GLS 85'|242 77"|
Website: http://www.brick-autosport.com
Facebook: http://www.facebook.com/pages/Brick-Aut ... 98?sk=wall"
Re: B19 VS B200
No difference in the injection system AFAIK. The B200 is a low friction version of the B19.
Re: B19 VS B200
Thing it i got a parts car with injection and a 85 GLS with carb.
I was thinking of swapping all the bits over. i hoped the loom for the injection was separate from the headlights and horn etc but its not.
Swapping just the entire loom + relaybox from the enginecompartment and the bit that goes to the ECU would be enough to convert to injection or am i missing something crusial.
Re: B19 VS B200
Mostly. There maybe some differences in the head. For instance I think the B200K uses water heating in the manifold and you have to block these ports up to convert to injection. Also check the holes for the cold start switch and idle bypass valve.
Re: B19 VS B200
i bet the B19 has a lazier cam and maybe even slightly lower CR as the B200
everything should fysically fit though, but i'd personally swap the complete engine; less work!
Re: B19 VS B200
Yeah im now pretty sure i will swap the entire thing.
Just wondering about the loom in the injected car, the headlights etc are worked into it too but it all goes to that fuse/relay box and one bit into the car thats connected to the ECU.
If i swap over all that stuff it should have all the bits i need to do the swap and have a functional injection system or are there fuses somewhere in the dash i will need too?
Re: B19 VS B200
injection loom is separate from the normal engine-bay loom (with the headlights, wiper motor etc)
Re: B19 VS B200
Sweet that's a load of my mind!
EDIT: Still i had the feeling it was joined at some points, i'll take a few pics of it
Re: B19 VS B200
I pulled out a B200E injection loom pretty easily so I think its not connected.
Compression ration from 1982 B19 in 360s is 10:1 same as B200s. However an 85 GLS should be a B200K (well mine was), does it have the Stromberg variable jet side draught carb?
Re: B19 VS B200
no it has the solex one but its busted
Re: B19 VS B200
Injection harness is separate. Here's a pic of LU-Jetronic's harness.
Re: B19 VS B200
Hmmmm interesting! i'm sure mine where hooked up on some points lemme get some pics of that tomorrow.
Re: B19 VS B200
engine side the only things hooked to the normal loom are starter motor, alternator, coolant temp sender and oil pressure sender
Re: B19 VS B200
Solex downdraft would be a B200K, unless its a mix and match engine swap already. Why do you think its a B19? The number is usually only on the timing belt cover, its possible it says B19 on the block, but thats misleading.
You will defo need to put in some core plugs into the head to convert a B200K to injection, not a difficult or expensive job AFAIK, but I've never done it.
Re: B19 VS B200
these are the 2 wires the injectionloom is wired to the other loom,
That other looms also has a connector that goes into the bendix coil.. will that present on the carbloom ?
