flywheel 740 940
Posted: 14 Feb 2011 10:41 pm
by finn
please help me i am in need of a solid flywheel for a redblock and a turbo pressure plate :?
Re: flywheel 740 940
Posted: 16 Feb 2011 08:43 pm
by theo2468
got the flywheel, and i believe there are different types of turbo pressure plates? so need bit more info
Posted: 16 Feb 2011 09:25 pm
by finn
well the flywheel i got is dualmass so the flywheel i need is the one that has got the crank senor on the block not on the bell houseing like on the 360 as for the pressuer plate wot ever turbo 1 wil fit the 1 you have got thanks for the reply
Posted: 16 Feb 2011 11:25 pm
by L14MNP
You need a 740 Turbo pressure plate.
Sounds like someone is building a 360T?
Posted: 17 Feb 2011 12:17 am
by finn
thanks i need a 740 turbo plate them if anyone has 1 please let me know and yes i am just starting to get round to fit the turbo engine just need some odd bits and bobs this flywheel/pressure plate problem is stoping droping the motor in
Posted: 18 Feb 2011 12:14 am
You need a flywheel from a 1990-1992 740, 1991- 240, or 1991-1994 940. Basically any 2/7/900 with an M46 or M47 gearbox and LH2.4 Jetronic engine management.
An early 940 will be the easiest one to find, I suspect...
Posted: 21 Feb 2011 06:34 pm
by finn
got i a flywheel today from truck busters in rugby the engine woz all ready out and only 20 notes happy days is defo a 740 turbo plate as i think i will just buy 1 new and i think i will drop it in at the weekend :360:
Posted: 21 Feb 2011 08:38 pm
Good find!
Yup - 740 turbo plate, 360 disc.
