front door removal
Posted: 28 Feb 2011 02:07 am
by bogbasic
Hello, I am trying to remove the driver's door on a 360 by tapping out the hinge pins with a removal tool, but the punch has got jammed inside the hinge pin, wedging it even more firmly in place. Is it possible to remove the door by unbolting the hinge, like you can with the rear doors. I haven't looked around the front door pillar much yet, just curious if anyone hints and tips, links, etc. Thanks.
Re: front door removal
Posted: 28 Feb 2011 10:40 am
Knocking out the pins is the only way. Is it the correct tool you are using?
When I'm breaking a car I cut the door off to get them off
Posted: 28 Feb 2011 06:38 pm
by bogbasic
Hello Dai
this is the tool I used....
http://www.lasertools.co.uk/item.aspx?cat=544&item=1186
... if I should be using a different one, please let me know. This one is quite difficult to hit hard enough as the hammer comes close to the paintwork, which I don't want to damage. The struts you welded 5 years ago are still holding up nicely, just trying to get the rest of the car to look as smart....
Posted: 01 Mar 2011 10:09 pm
by filthyjohn
It might sound mad, but try a bigger hammer! You can move it slower and place it more accurately while still putting massive force in.
Posted: 01 Mar 2011 10:14 pm
by sven360
Do you suggest sledge or bigger,John??
Posted: 02 Mar 2011 06:16 pm
I used one of those, its not really strong enough to get the Volvo pins out. The top ones can be removed with hammer and screwdriver or punch from the top (pull off the trim from the rain gutter). The bottom ones need the tool. My tool lasted for the 2 bottom pins only.
Posted: 02 Mar 2011 10:17 pm
by bogbasic
Ta all for that. I'll try with a bent pin remover (I think this'll give better scope for bashing it hard without damaging the paint) and a bigger hammer. Just have to knock out the old punch first!
