clear indicators
Posted: 05 Mar 2011 02:57 pm
anyone making them yet? cant find any
http://volvo300mania.com/uk/forum/
I looks very much like the plastic diffuser from a fluorescent light fittingHell Driver wrote:Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
The lad knows his light fittings!magnumpi wrote:I looks very much like the plastic diffuser from a fluorescent light fittingHell Driver wrote:Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
volvosneverdie wrote:The lad knows his light fittings!magnumpi wrote:I looks very much like the plastic diffuser from a fluorescent light fittingHell Driver wrote:Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
im 300-less old bean.sven360 wrote: I can obtain said diffuser for you VND if you want to try it.
Plan.sven360 wrote:Indeed you are.I forgot about that.![]()
I'll mebees collect a couple in case you get one later.
You can store 'em in the orange box
You my friend... Are absolutely right!magnumpi wrote:I looks very much like the plastic diffuser from a fluorescent light fittingHell Driver wrote:Good work! I've got a stack of cracked/damaged indicators I've saved for no apparent reason. A good use for them has just appeared. What's the white stuff? And more importantly where do you get it!
