last bunch of conversion q's
samueljon
Post by samueljon »
Last few questions I have about the conversion
What throttle cable is used on the non flipped mani?
Isit just a case of plumbing up a fuel pump or do I have to take the one out of the fuel tank?
Re: last bunch of conversion q's
Make one from your old cable. You just need the bulkhead bracket and bike bits.
I doubt you currently have a pump in the fuel tank? I run an Evo one in tank.
samueljon
Post by samueljon »
Didn't think I woul have anything in the tank was just checking :)
I have a 1.4 throttle cable so what parts do I need? What bike cable? :)
He means a bicycle gear/brake cable. Just mock one up when you've got the engine in for test fitting.
Oh and you'll need to know that when you use a fuel pump, you'll need a regulator set to 3 bar.
samueljon
Post by samueljon »
a bike gear cable of what?
and im using the fuel pump of the old car so should be fine that never had an issue touch wood
Vermilion
Post by Vermilion »
samueljon wrote:a bike gear cable of what?
From a bike with gears sm1
The valver needs more fuel than your old car's engine, so you should get a better one :)
Volvo 340 L 1983
Ah no vermilion, he's already got a valver. It's just a shell swap.
samueljon
Post by samueljon »
ye i am just swapping shells after skillfully writting my old one off :(
all bikes have gears do they not? pushbike, motorbike? what make? thats what i meant sorry
samueljon wrote:all bikes have gears do they not? pushbike, motorbike? what make? thats what i meant sorry
Dunno if this will help or not, but my Raleigh Ultra-Burner doesnt have any gears.
samueljon
Post by samueljon »
so i cant get a gear cable off that? damn :(
samueljon wrote:so i cant get a gear cable off that? damn :(
Fraid not. If you can find someone breaking a Grifter, youre in! :wink:
Post by filthyjohn »
:lol:
samueljon
Post by samueljon »
so what isit you use?
a bike gear cable of what? :)
samueljon wrote:so what isit you use?
Gear and brake cable is pretty much the same on a (peddle) bike isnt it?
I havnt been on for for years thjough so dont take that as gospel.
