1.7 fuel pressure
Posted: 21 Apr 2011 08:57 pm
by kylepiggy
what fuel pressure does the solex 28/34 need to run want to fit electric fuel pump a facet posiflow they have different models was thinking on getting the 1.5-4.0psi model if not they do a 4.0-7.0psi aswell and a 4.0-4.5psi any help would be great. also what are the fuel pipe fittings from the tank i imagine either 6 or 8mm thanks Kyle
Re: 1.7 fuel pressure
Posted: 24 Apr 2011 08:59 pm
by pettaw
Fuel hose sizes are 6.25mm standard pipe mostly, although I think the return might be a smaller diameter. Can't help on the pressure, sorry. Just out of interest what are you trying to achieve?
Posted: 26 Apr 2011 01:58 pm
by kylepiggy
all fixed now fuel pump broken just fitted facet solid state pump managed to get the pressure specs from the manual so went for 1.5-4.0 PSI pump
