Vario Belts and Water Pumps
Post by filthyjohn »
First up, a pair of GENUINE VOLVO Vario drive belts. Removed from my old red one which ran fine with absolutely no slippage. They have around 30K on them and exhibit virtually no sidewall cracking, certainly less than what is described as normal in the green books. They are a little egg shaped from storage but still flexible. I believe these used to be £100 EACH from Volvo, I want £50 for the pair (plus postage).
More CVT stuff; a full fully working primary and secondary unit and the beam that connects the two with the crossmembers that bolt it to the body. 30K miles only and in full working order. £OFFERS
I also have a brand new, genuine Volvo CVT Clutch, complete with shims and everything. Would like about £90 for that.
Brand new B14 water pump.
£10 (plus postage)
Brand new B19 water pump. (Bought in error years ago.)
£10 (plus postage)
Re: Vario Belts and Water Pumps
Does nobody way any of this stuff? I'll be moving to a smaller unit soon and I'll be tight for space so lots of large lumps of metal may have to be binned.
A friend of mine was mentioning interest bud, I'll have a word!
sven360
Post by sven360 »
filthyjohn wrote: I'll be moving to a smaller unit soon and I'll be tight for space so lots of large lumps of metal may have to be binned.
Much is the Manta??
Write it in your heart.
The code of the West.
With no engine as is, £2k but I ain't a motivated seller with this particular motor. Got a T5 here that looks like it'll fit, will be hacking the sump up soon to see if it can clear the rack. If it doesn't I'll be going for a 4.6 rover. Fiero is still here and I only want scrap price, engine does turn but it needs plenty work.
sven360
Post by sven360 »
What!!!!!!!!!
Did you lose the XE down the sofa or summit??
Check your sig Johnny,75 Manta C20XE.
You be a bad man.
10 hail Marys and a cold bath. :lol:
I'd have the amazon off you if I had the space :(
Speedy88 wrote:I'd have the amazon off you if I had the space :(
I think that car would have a nervous breakdown if it saw sunlight.
Ive only ever seen it lurking in shaddows like some kind of automotive Wampir.
torsten1
Post by torsten1 »
Cvt parts.... Talk to me, I need spares :D
sven360 wrote:Did you lose the XE down the sofa or summit?
XEs are old hat. The thing barely fits and the head gasket went as a result of a hose rubbing the bulkhead. The box/sump/mounts are worth good money so it's cheaper to put something else in.
torsten1 wrote:Cvt parts.... Talk to me, I need spares :D
The transmission units are potentially sold now but I still have some bits. Gear lever, declutching servo, undertray, clutch and some other little bits.
Alex Laidlaw
Post by Alex Laidlaw »
Hi John I'd be up for the clutch and belts if you've still got them and other bits that are postable!
Alex Laidlaw wrote:Hi John I'd be up for the clutch and belts if you've still got them and other bits that are postable!
PM coming!
torstentorsten
Post by torstentorsten »
Hi John, do you still have the primart and secondary cvt gearboxes? If so can you contact me please on 07827474642 and we shall discuss costs and collection :D
Kind Rgards
Torsten :340:
