T.J.
Posts: 248 Joined: 06 Jul 2011 04:44 pm
Post
by T.J. » 06 Aug 2011 12:18 pm
Looking at ways to mount my fuel pump. it's going under the car and being bolted to the floor.
I bought a bracket but it''s too wide to fit where I would like it, then I found this...
Only prob is there's no rubber sleeve for the pump to sit in, so no shock damping. Thinking this is important.. what do you guys think?
Trundle returns... Watch this space
Nimminz
Posts: 1669 Joined: 11 Jun 2010 10:56 pm
Post
by Nimminz » 06 Aug 2011 12:24 pm
I'm sure you could find a strip of rubber to fit inside it?
Fuse
Posts: 1364 Joined: 29 Jul 2004 09:03 pm
Post
by Fuse » 06 Aug 2011 01:39 pm
Fuel pump itself doesn't need shock damping. Damping is there to remove vibrations and noise as pumps are quite loud without it.
But like said above, you can fit a rubber sheet in between if you want.
jon-ovlov
Posts: 1291 Joined: 30 Jul 2010 09:45 pm
Post
by jon-ovlov » 06 Aug 2011 05:18 pm
What Fuse said. The rubber there I've always thought was more for grip on clamping the pump securely, preventing it from vibrating out or loose. A rubber strip would do the trick fine!
Speedy88 wrote:
Leave choke on, idling obnoxiously until neighbours peer out windows at the noisy exhaust
Give neighbours thumbs up
Rev engine to 7K
Exit street sideways
Win at life.
T.J.
Post
by T.J. » 07 Aug 2011 05:06 pm
ty for the replies people
Only prob is the bracket diameter is exactly the same as the pump. No space for a rubber strip
T.J. on 08 Aug 2011 11:34 am, edited 1 time in total.
Nimminz
Post
by Nimminz » 07 Aug 2011 09:18 pm
double sided tape / sticky pads?
Posts: 2266 Joined: 26 May 2009 05:34 pm
Post
by Ride_on » 08 Aug 2011 11:41 pm
Why not use the injection original mount? It mounts on 3 rubber cone things. Think these are the same as the air filter mounts.
T.J.
Post
by T.J. » 09 Aug 2011 09:33 am
Umm, because mine wasn't an injection
I sorted it now.. found another bracket that fits in with my plans
Post
by Ride_on » 10 Aug 2011 07:09 pm
I meant from another car and save you engineering something that might generate more noise. I'm a big fan of copying what has already been engineered unless it has been shown to be weak in some way.
