*** please help F7R conversion problem***
Posted: 16 Oct 2011 01:04 pm
by pulsarjoe
hi there everyone I am a 340 1.8 16v owner and am trying to convert a friends 340 from 1.7 to 2.0 and are struggling to get in running. As I have a car with an F7P, we have access to lots of spares that we know work and so far this is the situation.
We have a signal to the injectors tested with the noid light, however the sparks is VERY weak! Having swapped all components from my car to my friend we have found a wiring/voltage issue. We are using the F7R coil which is new and this is what we found:
three wires
1. 12V
2. Ground
3. 0.4 V dropping to 0.2 volts under cranking
on my car we found
on wire 3. 2.5 V with 3.5 under cranking and whilst running (approx. it was last week lol)
A friend said to check the wiring to the newly fitted rev counter clocks but with no difference
Would be very grateful if someone could give some advise as I am not great with wiring and am confused with what is producing this voltage
thanks in advance
joe
:340:
Re: *** please help F7R conversion problem***
Posted: 16 Oct 2011 05:29 pm
by T.J.
Might be a daft suggestion, but have you tried another battery / jump starting?
Sometimes batteries can wear and don't hold current when under load
Posted: 19 Oct 2011 01:36 pm
by pulsarjoe
thanks for the reply . battery was new with jump pack on also . It had plenty of power !!
please can someone help a fellow volvo owner!!
thanks joe
Posted: 19 Oct 2011 03:33 pm
Which F7R are you using, with which ECU?
