basically need everything to put an f7r into a 1.4. i have copy and pasted the list below from the wiki for all the bits im after basically plus a few others, cheers
1.7 sump
1.7 bellhousing
1.7 clutch
1.7 clutch cable (although a 1.4 can be used with a bit of inginuety)
1.7 front engine mounts (Rhs 3 bolt bracket to block - Lhs 3 bolt bracket to sump)
1.7 LHS rear bellhousing mount (1.4 can be used with a little trimming to clear clutch fork)( have had no clearance issues-kaos)
1.7 alternator mounts
1.7 water pipes
1.7/1.4 water temp sender(not sure if i need this, can someone verify? thanks)
extra bits:
5 speed gearbox, preferably unwelded diff.
5 speed Prop, (good to have a spare)
thanks, if theres anything else i need please advise
1.4 to F7R conversion bits wanted
Attack2001
Re: 1.4 (b14.4 engine long block) whole engine, w/e
I didnt get a reply from that gezzer about the engine, sorry man :/
no worries man, thanks anyway! plans changed a little
Re: 1.4 to F7R conversion bits wanted
I've got a prop and some mounts, pm me
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
if you fancy a f7p i got everthing you need but the diff is welded
pm'dquietman wrote:if you fancy a f7p i got everthing you need but the diff is welded
