Gearbox mounts 360 GLT B200
kelvingenders
Post by kelvingenders »
Are they available? Is there an alternative? Am I dreaming
Fuse
Re: Gearbox mounts 360 GLT B200
Post by Fuse »
kelvingenders wrote:Are they available? Is there an alternative? Am I dreaming
Those are NLA unofortunately, unless you can find some old stock from somewhere.
Mine were knackered also so I had to get a bit creative. Some pics of my solution at this thread. I used universal industrial bell-mounts combined with some home made parts and part of the original mount.
http://www.volvo300mania.com/forum-uk/v ... 90#p164072
kelvingenders
Have you got a picture of the dimensions of the rubber et al?
Post by bogbasic »
Hello, I sent one of mine to the person whose name I forget in Anglesey (the silicon bush specialist) to use as a template for new ones or something. Perhaps we should give him a gentle reminder....
kelvingenders
classic swede?
Post by Hell Driver »
I could do with some too!
343 DL (W 80) :-)
R.I.P. 77 343 DL vario :-(
kelvingenders
So could we all.
Well I've tried welding and it seems to be impossible. I left it with a 'professional' and he said it was 'not Aluminium' after trying to weld it, however I suspect he does not know about the different alloys. I also tried it at home and got an ashy round bead, with flashing/flickering around the surrounding metal immediately after stopping. It just would not flow.
Apparently Copper or Zinc Aluminium alloys are not weldable, would be nice to get it confirmed. Anyone have any resources to check the alloy? I'll check the markings but I don't think its marked. I might try and get it XRF tested.
Fundamentally looks like its a fabrication job. I'm thinking 2-4 steel plates welded. Does anyone think the dome is essential, it may capture the bush if it fails, or stop too much movement in all directions, a bridge or tube might be easier to make.
Should I go for a standard bush?
Also as a final thought, the domes and bolt holes crack/hole at the 'join', but the domes do not support the bushes directly, they will add strength to the main bracket. Has anyone ever had one break?
Logan360
Post by Logan360 »
I have a spare hanger bar or two that are still attached to diffs if someone wants to buy a pair, provided they on good condition.
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
I think Dai (Classic Swede) may be working on this problem or is likely to be looking into it in the near future.
343 DL (W 80) :-)
Yes I have been back onto these. I did have a look a long time ago and there were a number of issues to overcome. I still have the one bog sent me and will be doing something asap with them
Number 47
Post by Number 47 »
Logan360 wrote:I have a spare hanger bar or two that are still attached to diffs if someone wants to buy a pair, provided they on good condition.
Do you still have these Logan? One of mine has snapped and I am off the road.
What side do you need?
Number 47
Post by Number 47 »
It is the passenger side bgut I think it is caused by the drivers side seperating. My theory is that it has been twisting up on the drivers side and that's what caused the knock and then this. Might need more parts yet, the halfshaft tore out of the diff output shaft, 1 bolt snapped, I reckon the rest have pulled the threads out. I won't get to look properly till the morning but I think I'm going to need a new output flange for the diff. Will know more tomorrow.
Cheers.
Logan360
Post by Logan360 »
whereabouts are you for a postage quote mate?
Own:
86 & 89 360GLT
00 S80
02 Subaru GT30
Owned
