Remove tailpiece clutchhousing
SstennizZ
Post by SstennizZ » 09 Aug 2012 09:27 pm
The splines on the axle of the tailpiece are foobered on my 340 manual. Does anybody know if it's possible to remove the tailpiece without taking out the clutch housing?
Re: Remove tailpiece clutchhousing
Post by Chris_C » 10 Aug 2012 10:42 am
Which engine? B172 yes, it is, unless one of the bolts has become unpeened, which you won't find out till after it falls into the abiss.
Post by Ride_on » 15 Aug 2012 10:59 pm
Yes any 340 in fact (although not sure about auto).
Its called the clutchshaft, just remove the driveshaft then unbolt it, should just slide out with the shaft (also a useful centring tool).
