gear oil
volvo 360 GLT oner
gear oil
were do you change the gear box oil for a manul
- Duvel78
- Website Admin
Welcome to the forum! No nudity here, I have removed your avatar, sorry... But you can put a nice picture of your GLT!
Hugh's explanation is very useful but here is the answer to your question:
1 = plug to remove the oil
2 = plug to check the level and add oil
V3M for life!
V3M for life!
- antiekeradio
Indeed...antiekeradio wrote:nope, to much experience in totally screwing up bolt nr. 2
(use a 6-hex spanner.. dont even try with a 12)
I've tried to replace my gear oil... Luckily I did not take out the old oil first...
The head of the nr. 2 bolt is now smaller then the shaft of the bolt. We've used increddible force on the bolt but it just would not budge...
So if you replace the oil FIRST chack how @#$^#@$ up bolt nr. 2 is...
