Interior light :/
Benfraser
Interior light :/
Post by Benfraser »
My bulb went for the interior light and the boot one hasnt worked since i had the car and i think its the bulb as well so i was wondering will these bright ones actually work?
http://www.ebay.co.uk/itm/2-x-37mm-SV8- ... 2253wt_986
Thanks, Ben.........
frazeb
Re: Interior light :/
Post by frazeb »
buy it and then if it doesnt fit demand a refund without having to return the item
Check if there is a switch present and working on the gas strut.
DSCF1084 by macplaxton, on Flickr
The festoon bulbs look the right size to me.
Benfraser
Post by Benfraser »
I'll check that switch cos i think i can remember seeing the wires hanging off actually and i'll probably buy the bulbs. But the interior light doesnt look like the bulbs blown as the little thread bit is still ok inside the bulb... Any ideas?
Ben.......
Try the bulb on a battery? Check the switches on the hinge panels?
Benfraser
Post by Benfraser »
Yeah i'll try the bulb on the battery and i have had a look and it looks ok. Maybe just an old bulb but i'll test it
Also dunno if you know anything bout seats and subframes but take a look at my subframe topic? sm4
Ben.......
Any LEDs I've tried are sh1t. You can get decent ones, but they cost £10-£20 EACH. Avoid anything that says 'hi-power' or 'super bright' without a lumens figure. I don't even know where to start with how wrong all that advertising is, high power..struth.
Also, interesting terms and conditions on that ebay seller. They could be fined for it without you buying anything, its mostly illegal.
Benfraser
Post by Benfraser »
i'll bear that in mind cheers
Ben.........
baron_matt
Post by baron_matt »
I have that switch on my gas strut, but when the boot is shut the gas strut doesn't move far enough to activate the push switch. I've made a bodge with a 10mm long piece of fuel line that sits on the end of the plastic slider to make it activate.
Does this mean that there is something missing from my strut to make the switch work normally?
