340 2 door wanted (cheep)
Adam340
Post by Adam340 »
Hello all just joined the site I am looking for a 340 2 door project near Lancaster must be good shell not to bothered about mot or tax really and cheep as poss ;) thanks
T.J.
Re: 340 2 door wanted (cheep)
Post by T.J. »
look up "cheep" in the dictionary. you'll find it's the noise that birds make.
Then try again
Adam340
Post by Adam340 »
thanks for clearing that up
ffs TJ, it's not like his whole message was in text speak.
There was a 2 door shell that came up recently for cheap but generally you'll struggle to get a 2 door at all, let alone for under 500 with T+T. Those that are without T+T usually aren't that good condition :( But good luck, ebay is your friend.
Logan360
Post by Logan360 »
Agreed. That's a bit pedantic. good luck with the hunt. i haven't seen ANY whatsoever over here in New Zealand, let alone cheap ones :360:
Own:
86 & 89 360GLT
00 S80
01 Subaru Lancaster 6
02 Subaru GT30
Owned
Post by MCHUDD »
Good luck in the search. Here in Norn Iron, they are as rare as hens teath.
They are not that hard to fix up. I have fixed up a few in my time
and i am not a machanic.
theo2468
Post by theo2468 »
What are you plans for it? I could have something if you planning a engine swap and big suspension plans
C25 ECV-1985-Mk2 340GL-Kessy
A889 VUY-1983-Mk2 360GLS-RUF
Best appreciated when open.
Adam340
Post by Adam340 »
theo2468 wrote:What are you plans for it? I could have something if you planning a engine swap and big suspension plans
Looking to put a 460 turbo engine in one and make up the rest as i go along to be honest a good four door shell would do the job basically I just want a good shell to start with there is one on eBay a matt black one but it to far away just to go and have a look but thanks for everyone's input
Sam340turbo
Post by Sam340turbo »
I have a 2 door shell still got 1.4 engine in it but got no blocks or shocks or leaf springs or front spring and shocks £150 I'm in Norfolk thanks Sam
theo2468
Post by theo2468 »
I've got a 2 door shell with 13,000 miles on the clock!
DanYellowHeadlights
Post by DanYellowHeadlights »
I've got my shell up for sale.
White 35000 miles
No suspension at all, got doors, boot and windscreen, but that's it!
Has 5 link bits welded on shell so you can run coilovers on the rear!
150 collected from near brands hatch
Dan
