WANTED: diff output flange
Ade
Post by Ade »
Needing a diff output flange for my 360... (but 340 is just the same so I've since found out!)
One would be good, two would be perfect!
Anyone?
Ade
Re: WANTED: 360 output flange
Post by Ade »
Ade
Post by Ade »
Anyone know if this is shared with models other than the 2.0 360?
Diff output? Good luck dude, you're better off trying to find a complete diff. Nobody has half broken diffs lying around unfortunately :(
To answer your question, I'm not 100% on this but yes I believe they are the same across the board, 340 and 360.
Ade
Post by Ade »
Well either this or a complete diff.
Need to get the car back up and running!
Nimminz
Post by Nimminz »
Pretty sure they are all the same but there are 2 part numbers in the -'85 catalogue
3284959 - 8 -> Up to Chassis # 597180
3296509 - 7 -> B14 M45R ch. # 826226 onwards
-> B14 M47R ch. # 825898 onwards
-> B19 M45R ch. # 825898 onwards
-> B19 M47R ch. # 826716 onwards
But in the -'91 catalogue there is only the latter mentioned so I'd presume they all fit all diffs.
I'm guessing the earlier one is the one with a recess machined in for a gasket like the CVT's have. They used to use em on the MT diffs for a while i think. So presumably they'd fit but you'd need gaskets for them too.
Hope that helps
Matt
Ade
Post by Ade »
Is this a part that is likely to be source-able from a factors or Volvo? Or is this going to be a used part only?
Nimminz
Post by Nimminz »
I tried at my local volvo dealer and he said they were no longer available.
Doubt a factors would stock such a part, if any company ever re-manufactured them other than volvo.
Best bet's a used diff - even one that's buggered - as long as those parts are ok.
Ade
Post by Ade »
Thought that might be the case.
Happy to pay decent money for one (or preferably two!) posted to Glasgow. 340pw
Re: WANTED: diff output flange
Have you managed to find one as yet? If not I should have a complete diff.
Ade
Post by Ade »
Nope, sent out tons of emails, but nothing sourced as yet.
Ideally 2 flanges would be great so I have a spare sitting.
Will consider a whole diff if it comes to it....
I do have a spares car so could remove and post, would be faster to send as a complete diff unit.
Ade
Post by Ade »
Just let me know how much!
PM sent
