breaking with a heavy heart, but due to lack off time to use and having the cash would be useful for my garage I have decided to do it. Most parts are very new and covered less than 200 miles , some are brand new like the 5 link rear that have covered 0 miles. Prices reflect the quality and age of the item , most of these parts are custom or adapted to the car many are extremely rare or unique . large items are ono , cash talks and no dreamers or messers . Also i dont care if you think it is expensive , go out and build this car and see what it costs you
car is located in dartford kent
some postage available at extra cost
Engine
F7p
Head gasket changed blew between cylinders
ported and polished head
skimmed head
all valves lapped in
very clean and golden insidethe engine
all new gaskets
new thermostat
new cambelt and water pump £400
vgc flywheel and new clutch £40
spare vgc pistons, rods and crank £40
mocal 13 row oil cooler (front mounted with thermostatic sandwich plate) £110
new mandrel bent front pipe 2.25 stainless steel £60
Bandit 1200cc Bike carbs (on custom manifold) £350
Facet fuel pressure reg set to 1psi 15
facet reusable fuel filter £20
twin radiator fans £40
custom water system (sealed system with only 4 hoses and no expansion bottle and in hose rad. cap) £80
Williams exhaust manifold £60
full stainless exhaust motor bike back box £120
bell housing £35
prop shaft £60
welded diff gearbox good in all gears and v quiet £50
drive shaft £20 a pair
spare rocker box £10
bmw uprated engine and gearbox mounts and modified gearbox brackets £45
Suspension
Front
GAZ custom fully adjustable coilovers with 200sx front adjustable top mounts £450 (covered about 30 miles)
Poly arb bushes £15
poly arb link rods £15
Rear
brand new GAZ coilovers fully adjustable
new panhard rod set up , fully rose jointed, fully adjustable
cost £1100 £750
Brakes
Front
cleaned and painted calipers new pads and good discs £40
Braided front brake hoses £25
Rears
S.V.A approved Hi Spec rear calipers and new pads and custom rear hubs with disc conversion . longer studs for wheel spacers . It fits over a poor offset minilight with a 5mm spacer. £500 new calipers alone £ 400 for complete conversion inc. modified handbrake cables
Hydralic hand brake £50
rear of car fully braided from front bias valve
wilwood brake bias valve
All stainless expensive fittings
£150
shell
All bay loom tucked into front chassis rails
Door rub strips removed
Passenger door lock removed
Engine bay smoothed and all brackets removed
recent full inside and out respray (could do with a flat and polish but this is a drift car so don't expect a concours car)
All sound deadening removed
seat mounts removed and plates welded to floor pan
stereo but no speakers fitted
Cage boxes welded in
volvo owners club tax disc holder
rear strut brace welded in
will come with complete front looms
£600
A pair of 175 50 13 yokohamas with 5 mm tread £50
custom bay power loom £25
variomatic front bumper grills £25
mini washer bottle with pump £10
wiper arms that sit lower down the screen unknown
Plastic door cards £25
de-badged inc. front grill £25
snap off steering wheel and boss and wheel £50
6 point roll cage custom made and madrel bent out of cds (what it should be made of), fits very well and is tight but still comes on and out easy with front door bars that unbolt £600
flocked dash £80
rear light loom remade from trailer loom with large plug £20
Fibre glass bonnet inc bonnet pins £120
poly windows (fronts included not yet fitted) £ 50
Battery relocated to behind passenger seat inc. new large battery, battery box and power and earth cable and through bulkhead connecter £60
white weller wheels 13 x 6 ok tyres £80
Gold centred minilight alloys 13x7 (175/50/13) like yoko's on the front Michelins on the rear now battle scared £150
***please note the seats and harness' are not included in the sale ***
ok as you can see not your average Volvo 340!
Tried to be as honest as possible but please come and view and make your own opinions .
Please no messers
located in Dartford Da1 (5mins from the dartford bridge )
Any questions please call 07809 408 482
thanks joe
http://i973.photobucket.com/albums/ae21 ... 1730-1.jpg
http://i973.photobucket.com/albums/ae21 ... 1722-2.jpg
http://i973.photobucket.com/albums/ae21 ... 1988-1.jpg
http://i973.photobucket.com/albums/ae21 ... 1992-1.jpg
http://i973.photobucket.com/albums/ae21 ... 1994-1.jpg
http://i973.photobucket.com/albums/ae21 ... G_1720.jpg
Breaking big spec car, coilovers , 5 link , cage , etc.
Re: Breaking big spec car, coilovers , 5 link , cage , etc.
Is this a downpipe from the williams manifold? Also, how quick do you want pickup, as the next few weekends are a bit busy, might be able to do a silly evening trip though, unless it'd post ok?new mandrel bent front pipe 2.25 stainless steel £60
- 340GLT
Looks like my old 340 has lived her last days.....
Drift-rat-jim
Pics of wheel and boss plz mate and the weller wheels plz cheers
Sorry to bump an old thread, but that is one clean engine bay! wow
If theres some stuff available still I'll be in touch soon (guessing you aren't on the forum any more so I will ring you).
