CVT transmission Protective Cover
PeterVuggles
Post by PeterVuggles »
Hello all,
does anybody know where one can obtain the two parts that make up this item?
Alternatively can you run without them as mine are so cracked they vibrate and make a whirring noise that makes you think that a panel on the vehicle is about to drop off? My 343 is in the Canaries. This may influenc your reply. No salt on the road, very little rain but a pleanty of dust from the rough roads here and sometimes in the air when the wind is blowing off the Sahara.
thanks in anticipation
Peter
Re: CVT transmission Protective Cover
Well it's likely to be in the same state from a donor vehicle, give or take a few cracks. Given the bulk of the outer U-shape and the chance/expense/time of finding a NOS one, how about welding the cracks on the existing one?
thebear54
Post by thebear54 »
Alternatively, you can run without them.
The covers are there to protect against road objects (sticks, rocks, dogs, cats) getting into the Vario area. I personally have taken a few of my covers off and have never replaced them.
John
Yeah John, but you don't go out when it's raining. :P
Post by Hell Driver »
Running without is not advisable long term as at the very least gravel will get in, not good for the pully surfaces and belts. The car won't stop working but damage could build up. Dust will get in anyway but I wouldn't like the idea of anything bigger going in!
Be carefull with those pullys, fingers could easily be crushed. I've changed belts/units a couple of times years ago. It's not difficult with the correct tool which I once borrowed. I once made a homemade device (2 threaded rods with a detachable wooden block in the middle which worked well although more work than the proper tool.
Make sure there is alway a small gap between the pullys (secondary) and that the distance adjustment between the primary and secondary always has the belts running with a ring of silver showing at the outer edge of the secondary.
This is to allow for the belts bedding in. Adjust again after a few hundres miles. Failure to allow for this and checking of the gap is a major casue of belt failure from what I remember.
IMPORTANT:
Is you whirring vibrating noise the belts drumming on the cover? If so check belt adjustment/condition.
343 DL (W 80) :-)
R.I.P. 77 343 DL vario :-(
thebear54
Post by thebear54 »
macplaxton wrote:Yeah John, but you don't go out when it's raining. :P
Sometimes, unavoidable Richard. :wink: When it happens it can be a fun ride...LOL
Seriously though-If the car is used as a daily I would recommend repairing the shield and putting it back on to avoid daily road hazards.
John
