driving home from work tonight and car drove normal then revs pick up while cruising. ....
i hit the brake pedal and go back to throttle as normal and revs go back to normal.??
just done it couple more times just now and revs drop to normal everytime... could this be the brake pressure switch at fault??
and is there a part number for this item?? is the switch the one on the bottom of the servo unit??
any help would be great. thanks guys
vario 340 1.4 brake pressure switch
- volvodspec
Re: vario 340 1.4 brake pressure switch
no, this indicates that the fault is most likely in the tachometric relay; as the revs pick up under normal driving, not on driving off after braking. take the tachometric relay apart and carefully check the bigger solder islands (of the relay), if any of them looks cracked; resolder it.
http://www.volvo300mania.com/forum-uk/v ... =6&t=12314
thejackal01
will do. i did check this through few months ago when i put in the new transistor and did not see anything like that on the board at all.
will check it again though and double check..
it is really niggling at me now.
thanks for the info. will get oit checked out monday or tuesday and report back
thank you
thank you
