Volvo 345 starting issue.
Went out to my 89 340 1.4 today, she's been stood about 4-5 weeks, running and starting fine before i parked her up, but today alas she would not start despite numerous attemps. it turns over but couldnt get her to fire up, that is until i poured a little petrol into the carb, then it ran ok. Any ideas, i'm pretty new to these cars. cheers Neil
Re: Volvo 345 starting issue.
Leave it parked for more than a week and the float chamber will be dry as bone.
If it's struggling to refill this pot then perhaps the fuel pump could be a bit on the weak side and be sooking back a bit and not overcoming the air in the line.
Just use every other day and it won't happen.
Hi Beefy.
How is the interior coming along?
If you knew any lorry drivers makeing a trip to Belfast, i would give you
those GLT seats.
those GLT seats.
Thanks mac, i'll just have to not negelect her as much, i went out today after having her running last night and she fired right up.
Hi Mark, no still no luck on the seats
Trick here is to use petrol from accelerator pump, it often does not dry I have found and few fast kicks to accelerator before turning key might get just enough petrol to intake that car starts for short time, but during that short time fuel pump gets fuel and next startup will be enough to get car running.macplaxton wrote:Leave it parked for more than a week and the float chamber will be dry as bone.
Just use every other day and it won't happen.![]()
Of course on other hand, it is perhaps better that car is not starting right away when stood a while, so that oil gets into valvetrain during starting attemps.
