It is quite challenging to do blow tests as can't find hose that would be perfect fit, but compared to other side I think that there is no pressure buildup when doing tests and I can keep blowing.
One thing I found out was that idle speed changes quite a bit when using low gear switch now that I did seal carb leaks, before there was not much difference.
I could not spot any movement at front pulleys, no matter how I did accelerate, used low speed switch etc. and as my best attempts at blow test seem to be failure, then perhaps there is no way around the fact that I need to repair primary cvt unit.
What kind of work I'm looking in here?
I'm not quite sure if I can do the job or even swap another unit, so I would like to find out before hand a bit of things needed and overall task if I should attempt it or not, car that moves by itself is still better than one that is at pieces.
I need still to triple check blowing to other hose, but I do recall from previous testing that it did behave much better, too hot to attempt work at the moment though, so I thought I start preparation to worst.
Yeah, fail car, or is it just me?
Edit: I did read again mac's article about CVT, I had forgotten already few things in very short time, which is new normal, anyway I find there is still chance of failure being in hose instead of unit itself, which at least sounds like being easier fix, if that is the issue, need to lift also front of the car up and then rear much higher so that I fit under the car and can attempt to find those hoses, perhaps I take that overdrive side that seems leaking out and block EMV side, then blow from under the car to hose if that would reveal leak in hose itself, then I could be certain which bit is faulty really.
Not sure if hose failures are common or typical or what are typical issues, but better check all things possible while motivation burst lasts.
