1982 CVT B14 with Clutch problems
Posted: 19 Jul 2013 04:19 pm
I'm having clutch problems. Basically the problem has these effects:
1) High revs required to get the car to move and, I suspect, once rolling, higher revs than I should have (but no rev counter on car),
2) Going downhill or coasting, when I take my foot off the throttle the clutch dis-engages the CVT from the engine,
3) The 'hold in low gear' button lights but when the switch is in the on possition it seems to have no effect.
Here's what I've done to the car. None of the seems to have made any change:
1) New CTV belts,
2) Professionally refurbished carb (Solex 32-SE1A REN),
3) Fitted CVT Vacuum Valve overhaul kit,
4) Fitted CVT Tacho Relay ovehaul kit,
5) New exhaust (though doubt this is relevant),
6) Passed MOT (here it's called the ITV) test,
7) Looked for any cracked pipes so far as I can by crawling under the car and peering under the bonnet.
Downhill driving is particularly scary here (La Palma- the steepest land mass on earth) as I have a problm with the engine stalling due to air leakage past the inlet manifold gasket and hence no brake servo assist! Anybody know where these gaskets can be sourced as a single item? I've asked Borne-Built-Beauties and await an answer.
For safety reasons, should the car not have some facility to ensure that the clutch remains engaged when the vehicle is rolling? If so then this is where I should be looking. Point is where is it and how does it work?
1) New CTV belts,
